Foam supplies are not an issue. Depending on your usage, I can PM you suppliers. Tues when I'm back at work.
- Alpina 98
I'm going to bed early on New Years Eve
Not wishing to toast the New Tier in.
Little bits and pieces for repairs are not bud
But trust me I spend around £40k are year on foam
It is in very very short supply
Both dfs and dreams temporarily closed there factories last week due to foam shortages
Bmw history
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
- bladeowner
Car went in for it's MOT last week and passed but had an advisory on the front control arm bushes. I had thought the steering was starting to feel a bit more skittish and vague than it should be. I ordered some Meyle HD jobbies which came yesterday and fitted them today. Fairly straightforward but working on the drive slows the job down.
My Method:
1. Jack car up one side and remove wheel.
2. Remove aluminium underplate - 8 bolts and 3 screws for plastic undertray.
3. Undo 2 bolts on bush mounts and use puller to remove. (used a 10mm 1/2" socket on the end of the puller screw to keep it central)
4. Lubricate spigot and rubber and replace bush mount with new one. (I used a bit of tyre soap)
5. Put wheel back on and repeat for other side.
6. Replace aluminium undertray and refix to plastic undertray
7. Replace wheel.
Went for a test drive and the steering now feels like it used to. Will probably get the wheel alignment checked at the end of the month.
My Method:
7. Replace wheel.
2004 Sapphire Black 2.5 SE Z4 SMG
- McTyke
Removed washer bottle and flters and gave everything a good clean. 16 years of gunk removed. Jets of fluid on to windscreen and headlights seem a lot more powerful now.
Z4 2.5se Auto 2004 Sterling Grey Convertible
- Papa_Zee
Heck! Is that all?Beefy wrote: ↑Mon Oct 26, 2020 12:43 am Hi new to the forum, had my Z project just over a month and since I’m on furlough I’ve been making use of my time... last week I fitted new rear springs, shocks, and top mounts, relocated and repaired the roof motor, fitted poly arb bushes, and done the oil and filters. Got new front springs and top mounts to go on this week just need shocks to arrive.
E89 35is
- enuff_zed
Now you know what we'll all be doing this weekend!!
Novice question.....................does the bottle come out easily? I confess I've yet to look.
- McTyke
Pretty much. One 10mm bolt and then a bit of jiggling. Pull pumps out and leave wiring attached. That leaves the 2 sealing washers and filters in the bottle. I took them out and cleaned seperately. Filled a big bucket with water and a bit of bleach and submerged bottle. Bit of agitation and flushing with hose and inside bottle was like new.
Note of caution: Washer jets packed in afterwards - suspect some disturbed gunk had blocked nozzles. Pulled each one in and out from bumper a few times which seemed to pump the liquid back to the bottle and cleared blockage.
- Big Andra
Got an update on the progress from the body shop.
- 20201111-194314_.jpg (131.26 KiB) Viewed 1150 times
2009 E89 2.5 Alpine white.
Got a bargain today I know I don't have an alpina but just love how it looks and would be rude not to use it
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- sbryantgb
Replaced the tatty, torn and boring Gear shift gator
Took a good 90mins as the new leather is way thicker, but I thnk it was worth it
2003 Z4 2.2
Hi, where did you get it from and did it come with the plastic clip thingy?
Oh and it looks great
Cheers Kev.
2005 Titan Silver BMW Z4 E85 2.0SE
2013 Graphite BMW 120d Sport
1972 Pimento Red Triumph TR6 2.5 Pi
1979 Azzurro Blue Lancia Beta Coupe 1.6
- sbryantgb
Ebay
https://www.ebay.co.uk/itm/Gear-Handbra ... %3A2334524
They do not come with any kind of retaining clip (plastic, you have to reuse the original). They are way thicker than the original. (which you have to peel and scrape off.) Mines a base level car and the quality is superior to the original, but maybe not so on other models. I still have to do the handbrake, which I know is going to take even longer. I haven't driven the car since installing and the clips are quite stressed and the boot may pop out. If it does a few small tapping screws around the the outer shell and the plastic insert will probably sort this without any other major modification, and which will be hidden from view.
Hope this helps.
2003 Z4 2.2
Changed my ccv system took longer to take off old brittle ones
So snapped them off in the end
Top tip
If new ones aren’t bending into place
Run the under very hot running water to soften new plastic pipes
Top tip
Bmw history
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
Fitted the standard sound deadening + Hertz mid range speakers to the doors today. Big big upgrade in terms of sound.
Also finished hard wiring the dash cam in. Pretty happy with it.
Don’t want to see another scotch box again for a while though!!
I did this too a few weeks back - what a difference eh? Did you give the reservoir a clean out too? That was tricky given the awkward shape
