Just an E-tech kit off ebay.Phil40 wrote: Sun Nov 08, 2020 9:05 am Do you have used a "special paint kit" ? Or just a classic spray ?
Took the car for a spin. New diff ratio of 3.46 from 3.0i auto (old ratio 3.07).
1st gear still more than usable, 2nd easier to set off in without slipping clutch, 6th less like an overdrive but still high enough for the motorway.
Most of all it's transformed the car from 3rd to 5th. Really pleased with it. Thanks to all who did the write ups. Cheers mark
E85 3.0i 2005 maldives blue.
- ARCS
Dropped it off at the paint shop. Hopefully have it back for the beginning of next week
2009 E89 23i Alpine white.
2008 cayman 2.7 Arctic silver.
2003 E85 3.0 titan silver - sold
- Stevewi
Finished swapping grills to black ones today.
- 20201108_141802.jpg (171.18 KiB) Viewed 828 times
E89 35i Deep Sea Blue
E86 3.0Si Coupe wrapped orange and grey
E85 3.0i Sapphire Black
Sorted out this mess on back bolster
And a dam good clean too
- 4AABC8DD-5139-450A-80DF-E50467F46CA0.jpeg (179.97 KiB) Viewed 783 times
- 1583B698-F22B-4782-8454-F642E1C565A0.jpeg (127.58 KiB) Viewed 783 times
Bmw history
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
Waxed whole car yesterday with the old good Fusso coat
- IMG_20201107_122043.jpg (142.5 KiB) Viewed 768 times
04' 3.0i
- Alpina 98
You have achieved an excellent resultrays545i wrote: Sun Nov 08, 2020 8:02 pm Sorted out this mess on back bolster
If anyone else is looking to repair their seats due to collapsed foam please PM me. I'm able to source a variety of foams as I work for a commercial furniture manufacturer.
I'm going to bed early on New Years Eve
Not wishing to toast the New Tier in.
Well I am am an upholsterer
Bet you can’t get source much foam at the moment
I know I can’t
Due to German chemical manufactures
I know I can’t
Bmw history
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
- Alpina 98
rays545i wrote: Sun Nov 08, 2020 10:40 pm Well I am am an upholsterer
I know I can’t
Foam supplies are not an issue. Depending on your usage, I can PM you details of suppliers Tues when I'm back at work.
- Alpina 98
Foam supplies are not an issue. Depending on your usage, I can PM you suppliers. Tues when I'm back at work.Alpina 98 wrote: Sun Nov 08, 2020 11:36 pmrays545i wrote: Sun Nov 08, 2020 10:40 pm Well I am am an upholsterer
I know I can’t
Little bits and pieces for repairs are not bud
But trust me I spend around £40k are year on foam
It is in very very short supply
Both dfs and dreams temporarily closed there factories last week due to foam shortages
Bmw history
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
E85 2.2
F11 520d
E84 2.3d
E36 323i loon
E60 545i
E39 535i
E36 323i coupe
E39 523i
E30 318i lux
E36 320i loon
E30 318i
- bladeowner
Car went in for it's MOT last week and passed but had an advisory on the front control arm bushes. I had thought the steering was starting to feel a bit more skittish and vague than it should be. I ordered some Meyle HD jobbies which came yesterday and fitted them today. Fairly straightforward but working on the drive slows the job down.
My Method:
1. Jack car up one side and remove wheel.
2. Remove aluminium underplate - 8 bolts and 3 screws for plastic undertray.
3. Undo 2 bolts on bush mounts and use puller to remove. (used a 10mm 1/2" socket on the end of the puller screw to keep it central)
4. Lubricate spigot and rubber and replace bush mount with new one. (I used a bit of tyre soap)
5. Put wheel back on and repeat for other side.
6. Replace aluminium undertray and refix to plastic undertray
7. Replace wheel.
Went for a test drive and the steering now feels like it used to. Will probably get the wheel alignment checked at the end of the month.
My Method:
7. Replace wheel.
2004 Sapphire Black 2.5 SE Z4 SMG
- McTyke
Removed washer bottle and flters and gave everything a good clean. 16 years of gunk removed. Jets of fluid on to windscreen and headlights seem a lot more powerful now.
Z4 2.5se Auto 2004 Sterling Grey Convertible
- Papa_Zee
Heck! Is that all?Beefy wrote: Mon Oct 26, 2020 12:43 am Hi new to the forum, had my Z project just over a month and since I’m on furlough I’ve been making use of my time... last week I fitted new rear springs, shocks, and top mounts, relocated and repaired the roof motor, fitted poly arb bushes, and done the oil and filters. Got new front springs and top mounts to go on this week just need shocks to arrive.
E89 35is
- enuff_zed
Now you know what we'll all be doing this weekend!!McTyke wrote: Wed Nov 11, 2020 3:04 pm Removed washer bottle and flters and gave everything a good clean. 16 years of gunk removed. Jets of fluid on to windscreen and headlights seem a lot more powerful now.
Novice question.....................does the bottle come out easily? I confess I've yet to look.
