Atacama Yellow 35is build thread
- B21
I always wondered how you could accurately torque up a nut that you couldn’t get a socket on…
Result..
Result..
- IMG_3095.jpeg (124.26 KiB) Viewed 1556 times
- IMG_3096.jpeg (161.01 KiB) Viewed 1556 times
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting..
- Reamesy
They will come in very handy too, for hard to reach nuts and bolts
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- enuff_zed
Because I'm a pedant; you are extending the length of the lever slightly by using those.B21 wrote: Thu Nov 21, 2024 5:49 pm I always wondered how you could accurately torque up a nut that you couldn’t get a socket on…
Result..
Plius of course, the effective length will vary depending on the angle you connect the head to the wrench.
No doubt you'll come up with a clever calculation to adjust the torque setting slightly.
- Christopher72
Crowfoots rock, especially in not slipping off the bolt/nut. I can see how it would be valuable when extending.
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
- BMWZ4MC
When you use these with a ratchet handle or breaker bar, isn’t the centre of rotation at the centre of the square drive couple, and so offset from the nut by the length of the crow drive? Doesn’t the square drive couple orbit the nut effectively make this a crank?
S2000 GT - gone
- B21
BMWZ4MC and enuff_zed
If you use the crowfoot attachment so it’s at 90 degrees to the torque wrench rather than inline then there is negligible alteration to the applied torque ..if you prefer to use it inline then it’s a simple calculation to adjust it..
https://youtu.be/-hSmtLVESSM?si=GT3KiSnZEi01IMyk
- enuff_zed
Exactly.B21 wrote: Fri Nov 22, 2024 9:39 am BMWZ4MC and enuff_zed
At 90 degrees I believe old Pythagoras and his 'sum of the hippopotamus' comes in to play.
However, with your background Peter, I am sure you are aware that the chances of your torque wrench being accurate enough to matter are fairly low.
Even with 3 monthly calibration regimes, we always had to set the torque wrenches using the test rig in the stores before we went to the aircraft, and ensure we fully unwound the spring when we had finished.
- BMWZ4MC
I wasn’t concerned about the calculation for correcting the torque at any angle from 0 to 90 deg. Rather, I don’t understand how a lever can exert a rotational force on a nut when the centre of rotation of the applied moment is offset from centre of rotation of the desired effect. I’m sure I’ve missed something since these are commonly used tools!
Besides, my torque wrench came from Aldi
(although I do use somewhat more expensive torque wrenches at work)
S2000 GT - gone
- enuff_zed
That's the same as using one of those curved spanners for restricted access.BMWZ4MC wrote: Fri Nov 22, 2024 10:06 am Rather, I don’t understand how a lever can exert a rotational force on a nut when the centre of rotation of the applied moment is offset from centre of rotation of the desired effect. I’m sure I’ve missed something since these are commonly used tools!
In fact, even something as simple as Stilson wrench has the jaws offset from the handle.
Once the two parts are connected together they basically become one solid tool. The force is transmitted ok, but the leverage is changed, affecting the relationship between the force you apply and the force the nut receives.
- BMWZ4MC
That’s true, thanks. I’ve not seen these before, but I’m sure it’s pretty intuitive as soon as you use it.
I suppose it wouldn’t work too well when trying to use a torque wrench with a ratchet handle since that would give a rigid couple at a fixed angle (and so known torque correction) in the “locked” direction, but then that angular relationship would change as soon as the ratchet handle is turned in the “free” direction, necessitating recalculating the torque correction.
S2000 GT - gone
- B21
The way I looked at it it was better than guess I’m with an open jawed spanner…enuff_zed wrote: Fri Nov 22, 2024 9:52 amExactly.B21 wrote: Fri Nov 22, 2024 9:39 am BMWZ4MC and enuff_zed
At 90 degrees I believe old Pythagoras and his 'sum of the hippopotamus' comes in to play.![]()
What did horrify me was the effect of anti seize on the amount of torque transmitted to the nut/bolt…im waiting for some past tightening using that to snap..
- B21
I didn’t realise the Lidl torque wrench was so sophisticated?BMWZ4MC wrote: Fri Nov 22, 2024 10:45 am That’s true, thanks. I’ve not seen these before, but I’m sure it’s pretty intuitive as soon as you use it.
- BMWZ4MC
Aldi, please, I wouldn’t ever admit to buying tools in LidlB21 wrote: Fri Nov 22, 2024 10:46 amI didn’t realise the Lidl torque wrench was so sophisticated?BMWZ4MC wrote: Fri Nov 22, 2024 10:45 am That’s true, thanks. I’ve not seen these before, but I’m sure it’s pretty intuitive as soon as you use it.
I suppose it wouldn’t work too well when trying to use a torque wrench with a ratchet handle since that would give a rigid couple at a fixed angle (and so known torque correction) in the “locked” direction, but then that angular relationship would change as soon as the ratchet handle is turned in the “free” direction, necessitating recalculating the torque correction.![]()
S2000 GT - gone
- BMWZ4MC
I experience terrible dissonance about the use of anti-seize, especially when it comes to wheel bolts…B21 wrote: Fri Nov 22, 2024 10:45 am What did horrify me was the effect of anti seize on the amount of torque transmitted to the nut/bolt…im waiting for some past tightening using that to snap..![]()
S2000 GT - gone
- B21
BMWZ4MC wrote: Fri Nov 22, 2024 10:48 amAldi, please, I wouldn’t ever admit to buying tools in LidlB21 wrote: Fri Nov 22, 2024 10:46 amI didn’t realise the Lidl torque wrench was so sophisticated?BMWZ4MC wrote: Fri Nov 22, 2024 10:45 am That’s true, thanks. I’ve not seen these before, but I’m sure it’s pretty intuitive as soon as you use it.
