Converting a Z4M to an automatic ????? Blasphemy !
- Martyn
Don't forget to Geert is a HTG dealer, and supplies wiring services for HTG users, so has a vested interest
- 1536Z4
Ok I will bare that in mind . I really don`t want this to turn into a " mud throwing " thread but if we could sort out a way for it to work wouldn`t that be great for us and anyone else that would like to do the same When I say we I mean anyone that has the technical knowledge because I definitely cant help there
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Martyn
Lol, no worries.
If you want something that works out of the box, is tried and tested and is suitable for a daily driver then the MaxxECU route, with an S54 loom is the way forward.
- 1536Z4
Thanks Martyn it would seem the logical way to use the S54 loom but as I say my technical skills especially electronics are almost zero .
- RvsBmw
Do you know Geert? Or contacted him?
I check his FB and saw that an "expert" stopped by to fixed the software.
The MaxxECU is "the" solution between a S54 and DCT from the M3/M4?
Btw im the only one that is wondering when de ZF gearbox from the new G80 wil hooked up? Buttersmooth shifting, not as race but good .
Current: BMW Z4M Coupe '07 (one-off) | Midnight Blue Metallic | Syrah Blue Leather | OEM CSL's | Aero's
Gone: BMW Z4M Coupe '08 | Sapphire Black | Bicolour Silverstone Anthrazit | OEM CSL's | Aero's
- Martyn
I don't know him personally.
MaxxECU with the 135i / 335i / Z4 35i E series DCT gearbox is the way forward. F series gearbox support is still in development with MaxxECU.
If you want to use the 8HP ZF boxes then TurboLamik is the way forward, lots of HTG users have switch to the TurboLamik setup and are VERY happy.
Bumping an old thread as I found this earlier - https://www.e46fanatics.com/threads/e46 ... t.1294967/
ZF 8HP70z automatic transmission swap onto an M54. Seems like it could be a good option
Size-wise, would it fit straight in, or would there need to be some modifications to the transmission tunnel?
...and why an 8HP70 rather than a 8HP45 (what I have in my 320D) or 8HP50 (in the Zupra)?
- 1536Z4
Thank you I have had a read through and it would seem that other people are looking into other options also . I have filed it in my to do folder
- 1536Z4
He briefly refers to the 8HP45 on the second page as someone asked the same question .
Discussion Starter · #22 · 2 mo ago
rwd7 said:
Is there not an 8HP with the same bellhousing as the DCT or did you go for what was available?
The 8HP45, but it is not fully supported by the tuner. It will be supported I believe within 2022 but I preferred a proven solution now, which is the 8HP70. I'd rather modify it to physically fit and not to worry about tuning instead of the opposite. I am not doing the same mistake again - especially with tuning.
Also, George Hill (Hill Performance Bimmers), Austin TX is working on the above (8HP45/70 + Turbolamik TCU) if you're looking for a more localized support. Iniciar sesión en Facebook
It looks to fit really easily on the E46, so shouldn't be an issue for the E85/6 either.
Choice of gearbox basically comes down to picking the one that has the best aftermarket support
Why not just buy a non M Z4 which is an auto or just get a different auto roadster or convertible?
M4, M6, SLK, SLC, E Class, etc. SLK 55AMG might come with an auto. Seems like a lot of work and money for something which you then won't be able to sell later on down the road as it would need someone familiar with it's history.
Nobody modifies their car expecting to get their money back.SonnyA85 wrote: ↑Fri Mar 18, 2022 4:08 pm Why not just buy a non M Z4 which is an auto or just get a different auto roadster or convertible?
You do a project like this because you want to. It doesn't have to make sense to anyone other than the person doing it
- 1536Z4
This exactly
- MikeyH
Am I missing something, why can't you just use the auto box from an auto Z4 or is the reason it's not strong enough?
