Steering Column Fix - Torque Sensor (save £2000)
Z4JOE91
Post by Z4JOE91 » Sun Aug 13, 2023 9:32 pm
Gotcha and yes greasing the worm gear. I think I manage to post a photos below. I hope the BMW gods help me out getting it right the first time lol
2004 z4 3.0l SMG :driving:
Z4JOE91
Post by Z4JOE91 » Tue Aug 22, 2023 9:46 pm
Conclusion to my 611c problem. I got the used steering column from eBay for about 100 bucks and it worked out perfect! I was able to recalibrate everything and had moved the eccentric ring about 6mm so lets hope its good there. Its like 90 plus degrees outside here in Florida so this will be a perfect environment to see if I get sticky steering. thanks for all the help!!
enuff_zed
Post by enuff_zed » Wed Aug 23, 2023 7:46 am
:thumbsup: Well done
HQ of 'Norfolk Zed Rescue'.
yg54sg
Post by yg54sg » Wed Aug 23, 2023 10:39 am
I have gone hydraulic but while I was pulling the EPS motor I was thinking it wouldn’t be too hard to install a 12v pc fan under there blowing on the area with the eps motor and it’s worm gear as the reality is metal expands very slightly with heat and a fan would keep it consistent steering feel. I doubt it would need much airflow just some airflow.
54 3.0i SE, Sterling Grey, 6sp Manual, Dream Red Heated M Sports Seats, Pro Navigation, Carver DSP Sound, Xenon,
Mods: facelift rear bumper + lights LCM reprogram, LED DRL rings, Clear hockey sticks, clear side repeaters, powerflex bushes
noz85
Post by noz85 » Tue Dec 03, 2024 12:29 pm
Is this the same unit/EPS found on thr E89? Ours (2016) has a steering-torque sensor fault (63ED). Thr symptoms is the EPS cuts out when you approach full left lock. Turn off thr car and restart the engine clears it.
The car has a private warranty until June 2025 so we are hoping we can cover the repair with that. Not sure if is the actual sensor or an angle issue or the motor maybe needing a refurbishment.
noz85
Post by noz85 » Tue Dec 10, 2024 2:33 pm
Any help appreciated for my previous post. Looking at a £3000 bill to "replace the steering rack"
lobos
Post by lobos » Fri Jan 10, 2025 4:43 pm
Mike Le'mans,
Good evening
I have a BMW Z4 and 85 I have the steering servo problem error 611c
Can you overhaul it?
Thank you
email:lobosracing@tiscali.it
AlexG1080
Post by AlexG1080 » Wed Apr 30, 2025 4:14 am
Hey everyone! Amazing info on here. I had my EPS module rebuilt by ECUtesting and upon reinstallation, it threw the 611c fault. I’m in this $700 so far, and will try the torque sensor rebuild, but if that fails, can I just buy a column and attach my freshly built EPS module onto it? I see a pinhole on the face of the EPS module but not sure how to avoid wasting more money and time by ruining another torque sensor wirhba second hand column.
