How To - Steering Wheel Spoke Refurbishment
Grwilliams23
Re: How To - Steering Wheel Spoke Refurbishment
Post by Grwilliams23 » Thu Aug 06, 2015 1:59 pm
sk93 wrote:
Grwilliams23 wrote:Has anyone else done this refurb? I used plastidip and the results were fantastic...until a recent heatwave ( rare in Swales!)! It had a shrinking effect; and peeled off around the edges.
Just wondering if anyone has used a different product and how it has stood up to regular use?
Paint or plastidip still I believe.
I use plastidip and I get about a year out of it before it tears / wears through.
I used plastidip this time and after the heat it lasted a week. Think I'm going to try a Matt black spray this time around and see how it goes.
srhutch
Moderator
Moderator
Post by srhutch » Thu Aug 06, 2015 2:07 pm
Paint will last much longer than plastidip. If you weren't in contact with the spokes all the time then it would be fine, but paint will be better.
Buzz
Post by Buzz » Wed Sep 09, 2015 6:44 am
Hello,
The link for removing the air bag has gone stale. Any other suggestions on where to get this step? Also, any reprogramming peculiarities to know about after reconnecting the battery?
Thanks!
craigdm
Post by craigdm » Tue Jan 19, 2016 8:53 am
Sorry Buzz I can't help you, but I'm surprised someone hasn't passed through and commented recently.
Z3 rare 2L Straight 6. Should have kept it!
E85 3.0Si sold back in 2014. Should have kept it!
E89 20i just arrived 2021
srhutch
Moderator
Moderator
Post by srhutch » Tue Jan 19, 2016 2:20 pm
Buzz wrote:Hello,
Thanks!
Just disconnect your battery and leave for 30 minutes or so for any charge to clear.
Then insert a screwdriver through the holes on either side of the steering wheel to press on the spring clip which will release each side in turn.
Buzz
Post by Buzz » Thu Jan 28, 2016 11:30 pm
Thanks very much. I found a video on YouTube that showed what you have said. This was a good afternoon project and the wheel looks much better. I highly recommend it.
carl2990
Post by carl2990 » Sun Oct 30, 2016 9:56 am
I've started painting the back parts of the steering spokes, gives me some room for error before trying it on the visible front parts!
A few images below show the original, then painted with Plasti-kote matte black. the problem with this is even after drying the final layer is very soft and is easy to scratch.
The last image is sprayed with Plasti-kote satin clear coat, altough it doesn't look as good, it's much more resilient
midlifestage2
Post by midlifestage2 » Sun Oct 30, 2016 10:16 am
Bing wrote:Great write-up srhutch :thumbsup:
Time & delivery of goods permitting I'll do mine next weekend and post some pics for those of us with flappy paddles...
EDIT - I also use mine daily so can report back on wear as and when :driving:
I will look forward to this , myself also being lazy in the left hand and leg department :D
Snowman
Post by Snowman » Sun Dec 18, 2016 6:24 pm
I'm thinking of doing the same refurbishment to my steering wheel since it does not match the rest of the car..
However has anyone found a way to do this that actually lasts?
I dont really see the point in doing this if the new paint will just peel off the first time the temperature gets above 20degrees celsius..
srhutch
Moderator
Moderator
Post by srhutch » Sun Dec 18, 2016 7:20 pm
Normal paint works fine, it's just Plastidip that doesn't
Snowman
Post by Snowman » Sun Dec 18, 2016 7:39 pm
srhutch wrote:Normal paint works fine, it's just Plastidip that doesn't
Oh okay thanks for the reply!
Do i have to use a specific paint for plastics?
Or any plastic primer?
Snowman
Post by Snowman » Mon Dec 19, 2016 10:28 pm
Has anyone else repainted the covers with paint?
If so, did you use any specific plastic paint or just one layer of regular paint?
What about clearcoat?
Argenta
Post by Argenta » Tue Feb 14, 2017 5:17 pm
Great guide!
I'm painting mine satin black for the alcantara wheel.
Has anybody managed to get ALL buttons off before painting..?
Would make things easier.
charlie8
Post by charlie8 » Wed Feb 07, 2018 11:08 pm
Another refurb complete
I read alot of issues about getting the airbag out, but just ram the screwdriver in with force, all your doing is pushing that big spring inwards that looks like a massive paper clip vertically mounted, it'll click out. Took me 2 mins.
80% of the time was just getting that nasty rubber coating off. I got it all off, used meths, white spirit, all purpose oil spray and 800 grit, with a rag it finally comes off with mix of all those.
I left the buttons in, tried to undo the 4 mini torx, but they were just too small and did not want to damage, so just masked off, making sure the tape poked well down the gaps
Went with Plasti-Kote matt back - I never want to see that rubber stuff again, once it starts to wear just looks ugly, mine looked like a bad sunburn peel
5 coats in all with a mid 1200 grit flatner
There's nothing in the dark that isn't there in the light .... except fear
srhutch
Moderator
Moderator
Post by srhutch » Wed Feb 07, 2018 11:12 pm
I re did mine last year with Matt black and then a special lacquer which gives a very similar feeling to the original finish, a soft/rubber finish.
It also seems to be holding up well.
