Project Restoration Zed- Major step forward(photo update p6).
enuff_zed
Project Zed is here- help please
Post by enuff_zed » Sun Dec 03, 2023 10:45 am
paddy wright wrote: Sun Dec 03, 2023 10:40 am
enuff_zed wrote: Sun Dec 03, 2023 8:30 am
paddy wright wrote: Sat Dec 02, 2023 11:16 pm Found the leak in the boot- coming from round the light and into the boot- next on the fox list. For the interior leaks any further ideas- the carpets are wet underneath but the roof drain plugs are clear and the door membranes seem fine. My thoughts are wondering if water could have been let in from rain and just needs to dry out?
Even if the membranes look perfect it is a common issue for them to lift from the panel. Bottom edge, about six inches back from the front corner, the metal work dips in and the membrane parts from it. Check there just in case.
I’ll take a look this week. Hopefully it’s a simple fix, thanks again for helping.
If it is that then forget trying to seal it with Butyl Tape, it just pulls away again.
I was recommended and heartily endorse Tec7 black sealant.
HQ of 'Norfolk Zed Rescue'.
Online
bigwinn
Post by bigwinn » Sun Dec 03, 2023 10:48 am
tec-7
seals black holes
EWS Delete PM me
Coding- airbags etc PM me
pvr
Post by pvr » Sun Dec 03, 2023 11:50 am
bigwinn wrote: Sun Dec 03, 2023 10:48 am tec-7
seals black holes
Every accountant should have some
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Online
bigwinn
Post by bigwinn » Sun Dec 03, 2023 12:10 pm
pvr wrote: Sun Dec 03, 2023 11:50 am
seals black holes
Speak to my ex wife (if we are talking black holes)
EWS Delete PM me
pvr
Post by pvr » Sun Dec 03, 2023 12:23 pm
If we are talking financial black holes I hope :rofl:
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Online
bigwinn
Post by bigwinn » Sun Dec 03, 2023 12:33 pm
pvr wrote: Sun Dec 03, 2023 12:23 pm If we are talking financial black holes I hope :rofl:
no comment
EWS Delete PM me
paddy wright
Post by paddy wright » Wed Dec 20, 2023 11:03 pm
So had time last weekend to have a wee play with project Z. Leak into the boot sorted by resitting the rear light wiring rubber bungs and replacing the third brake light which cracked in the frost. Took door card off and yes- the membrane was a mess so this is next on the list. Sadly also found the front panel is dented so this will also be replaced along with the bumper now.
Satisfying to save the wee Zed.
paddy wright
Post by paddy wright » Fri Dec 29, 2023 12:18 pm
I’m going to refit the standard side skirts- any advice on how to do this?
Online
Barty
Post by Barty » Fri Dec 29, 2023 12:32 pm
paddy wright wrote: Fri Dec 29, 2023 12:18 pm I’m going to refit the standard side skirts- any advice on how to do this?
Remove the fasteners in the wheel arches, remove the retaining bolts underneath. Remove the fasteners underneath the skirt. The only thing holding them on now are the clips along the upper interior side and the two plastic clips on the rear fender and front arch. Prise these off (take a bit of force) and pull the skirt away from the car.
Fitting is the opposite: first push the skirt home with the male-female fasteners, then align front and rear and reseat in the carriers on the body panels. Tip: put both the male and female part of the fasteners on the skirt, align with the body holes and push. Replace these for new when you do, the old ones often are past their best.
Refit lower fasteners, wheel wells and admire your handiwork :thumbsup:
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
pvr
Post by pvr » Fri Dec 29, 2023 12:36 pm
…. And put them up for sale for £1k :lol:
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Online
raymond.harper
Post by raymond.harper » Fri Dec 29, 2023 12:40 pm
Remove the old ones first! Two threaded 8 mm screws, one in the front wheel arch and the other underneath the sill towards the rear. Then remove about 8 pop rivets under the sill. From the rear pull the sill away towards you, I used a trim separator. Move the instrument along to the front slowly prising the sill away
sill 3.jpg (96.72 KiB) Viewed 397 times
sill 2.jpg (154.43 KiB) Viewed 397 times
sill 1 .jpg (96.72 KiB) Viewed 397 times
paddy wright
Post by paddy wright » Fri Dec 29, 2023 1:07 pm
Thanks guys- the Aeros are off and sold to Wassup a few weeks ago.
Joez4
Post by Joez4 » Fri Dec 29, 2023 5:25 pm
Hi,
Are you still selling the tail lights?
04 2.2i Sapphire Black Roadster
paddy wright
Post by paddy wright » Fri Dec 29, 2023 9:41 pm
Joez4 wrote: Fri Dec 29, 2023 5:25 pm Hi,
I will be soon- are you interested?
paddy wright
Post by paddy wright » Fri Dec 29, 2023 9:43 pm
Side skirts back in place and door membrane temporarily patched until I get a new one.
