Sat Nav Retrofit Fitting Details
cagatay87
Post by cagatay87 » Fri Sep 08, 2017 3:25 pm
does anyone have pdf or diagram for how can i cut dash?
any measurement?
or any pdf for template?
markplant
Post by markplant » Fri Sep 08, 2017 5:33 pm
You might be better trying a breakers for a dash top from a nav car
markplant
Post by markplant » Fri Sep 08, 2017 5:34 pm
On eBay i think it's classiccarspares2016
cagatay87
Post by cagatay87 » Sun Sep 10, 2017 10:01 pm
Nothing like that...
srhutch
Moderator
Moderator
Post by srhutch » Mon Sep 11, 2017 6:51 am
Just do as I did and make your own. Just remember you can make the hole bigger, but not smaller.
markplant
Post by markplant » Mon Sep 11, 2017 7:45 am
eBay number 263152522471
cagatay87
Post by cagatay87 » Mon Sep 11, 2017 8:01 am
I just need template with paper to cut , not compleatly dash bro
pvr
Post by pvr » Mon Sep 11, 2017 8:13 am
I have fitted two of these, if you take a thin piece of cardboard it is easy to make the cutout and you can test it using the screen. Point to remember is that there is a small edge at the front that you don't remove and the legs of the screen have holes that need to lign up with the screws under the dash surface.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4M Midnight Blue
VW ID.3
Previous:
Z4 3.0 SI black sapphire
Z4 3.0 Toledo
srhutch
Moderator
Moderator
Post by srhutch » Mon Sep 11, 2017 1:44 pm
That's not a bad price. THey were £200 when I did mine and was looking for a just in case solution :lol:
pvr
Post by pvr » Mon Sep 11, 2017 1:53 pm
ah yes, your rush job :lol:
I took 3 evenings if I remember well, to avoid the just in case ... measure, re-measure, cut, cut a bit more etc :D
You did take 3 years to finish it off though :poke:
Never again though.
Current:
Abarth 595 Comp.
Z4M Midnight Blue
VW ID.3
Previous:
Z4 3.0 Toledo
srhutch
Moderator
Moderator
Post by srhutch » Mon Sep 11, 2017 1:57 pm
I did the measure twice cut once stuff, but the concern was the dremel slipping, although I did protect the dash the best I could.
3 years, you checky fecker :lol:
Where you been hiding anyway, not that we've missed you :P
branebmw
Post by branebmw » Tue Oct 16, 2018 11:40 am
hello
I want to upgrade navi system to my bmw z4 2006 , i buy radio professional and monitor, what else do I need to do?
What is the catalog number of the cables?
Best regards
branebmw
Post by branebmw » Wed Oct 17, 2018 1:37 pm
i need wiring loom serial number 61120301701
Alemito
Post by Alemito » Sun Jan 10, 2021 6:40 pm
Where can i find a cutting template?
dj_jormi
Post by dj_jormi » Wed Apr 12, 2023 9:56 pm
Template original: EBA 0129201834
cost 1$ in bmw
