Thanks, I'll try this.. I failed to notice that Torx you mentioned.
Meds 3.0si Coupe - Update: Reassembled.
Meds 3.0si Coupe
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
Meds 3.0si Coupe
I took it for a motorway test drive yesterday..Spriteracer wrote: ↑Tue Oct 31, 2023 10:12 am I would love to know how effective your void filling is when you finish it. I have been chasing a resonance ever since I have had my car and have put heavy foil backed bitumen type sound deadening on the boot floor, under it over the exhaust, and along the underside of the tunnel above the prop. Sadly none of this has made much difference. I was thinking of packing the hidden voids with rockwool acoustic insulation or similar - flexible, fireproof and doesn't rot if it gets wet... as used in floors and partitions in houses.
I reckon I've reduced rear road rumble noise by 20%-30%.
The overall noise in the cabin is now equal between the front and rear, rather than everything bombarding from the boot area.
It'll be hard to tell what part made what difference. I basically went crazy, every part of exposed metal that I caould get to, had 6mm insulating foam stuck to it. For the voids, I insulated and then stuffed large amounts of bubble wrap into the corners.
I'll get under the black plastic behind the seats next.
Then move onto the doors and then possibly for floor.
- 1536Z4
Meds 3.0si Coupe
What insulation did you use ? I have done the boot floor the same as Spriteracer but it didnt make much difference . I may have a go at the rest of the panels if your results are positive .
- P1110549.JPG (224.45 KiB) Viewed 766 times
- P1110548.JPG (190.87 KiB) Viewed 766 times
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Meds 3.0si Coupe
6mm sticky rubbery foam. Cheap from Ebay. It's really squashy so can be compressed.
Your job looks tidy! I stayed away from the foil stuff as to my untrained logic it looks like it will reflect noise, rather than absord it.?
Did you do behind the plastic trims around the sides and rear? And also the voids behind your shoulders?
- Spriteracer
Meds 3.0si Coupe
Meds - Thanks for the update. The foil backed stuff is 5mm bitumen and is meant to stop panels resonating rather than absorbing sound waves. It doesn't seem to have much effect on voids though which is why I thought I would try the Rockwool which should. 1536Z4 has gone further than I have as I just concentrated around the exhaust area which is where the booming seem to be generated. Some days it seems worse than others but that might just be my perception. I thought at one point the exhaust back box had been altered but I didn't see any sign of that when it was removed for other work. Car sounds fine from outside so I don't think it has broken internally.
2007 E86 "work in progress"
- 1536Z4
Meds 3.0si Coupe
No just what you can see . I put some sticky felt tape around the plastic edges to stop the rattles . Don`t really want to add any more bitumen sheet as it is all added weight but may give the foam a go .
Meds 3.0si Coupe
The cheap rubber foamy stuff I used weighs next to nothing, so I went crazy and stuck it everywhere I could get to.
It's definitely a product to absorb noise rather than dampening panel movement like the foil stuff does. I see that attached to large panels like roofs and doors.
When I start the cabin area, I'd like to tackle the rear bulkhead from the other side, and those two voids from behind the seats.
- TOMGREEN413
Meds 3.0si Coupe
Sorry for asking but where would the washer filters be located please? A job I'd like to do .
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- Mr Tidy
Meds 3.0si Coupe
The filters are on the washer pumps and sit inside the fluid reservoir. You'll find them when you pull the pumps out of the reservoir - they are a push fit.TOMGREEN413 wrote: ↑Tue Oct 31, 2023 10:47 pm Sorry for asking but where would the washer filters be located please? A job I'd like to do .
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Meds 3.0si Coupe
Delivery:
Bulbs:
I noticed one of my headlight bulbs was orange and a little dim, I have an MOT next month so it makes sense to sort it.
While I'm at it, I plan to remove the headlights and attempt to clean up the inside of the plastic lenses, they're a little foggy and bug me.
I understand this process involves a front bumper removal, headlight removal and then remove the projector glass. This should give just enough room to poke a cloth through, glued to a chop stick and give it a wipe over.
I'll also look to clean the projector glass.
M Sport (Suplex) springs:
Who knows what the car will feel like with Eiback Pro springs rear and Suplex springs front..
But it's an experiment I'm willing to try until I get some Suplex rear springs delivered.
If it feels fine after tracking and doesnt look odd, I might even keep it.
I need to raise the front end of this car, it rubs the front arch liner, scraps the flaps infront of the front wheels, and Mrs Meds is scared to drive it.
It's a right royal PITA and takes most of the enjoyment away when I'm clenching and grimacing behind the wheel.
Bulbs:
- TOMGREEN413
Meds 3.0si Coupe
Thank youMr Tidy wrote: ↑Tue Oct 31, 2023 10:52 pmThe filters are on the washer pumps and sit inside the fluid reservoir. You'll find them when you pull the pumps out of the reservoir - they are a push fit.TOMGREEN413 wrote: ↑Tue Oct 31, 2023 10:47 pm Sorry for asking but where would the washer filters be located please? A job I'd like to do .
Meds 3.0si Coupe
I needed to change a bulb, why stop there?
I had a misty drivers side headlight on the inside of the 'glass' and it was clear that the projector lens had gone foggy, too. The passenger side wasnt much better.
Bumper off:
Operating table:
After removing the ignitor and bulb, the projector needs to come out.
Getting the projector lens out was a faff. 4x nyloc nuts that need to be unscrewed, along with an absolute PITA connector for the main/dipped flap. A few of the bolts unscrewed fromthe housing due to the nyloc nuts having a little too much bite, this stumped me for a bit but working methodically, the issue was overcome.
A look inside once the projector glass was removed:
A load of different cloths with Isoclene electrical cleaner removed the foggy grime easily. Getting into the corners of the 'glass' was a pain but a chopstick to push the cloth around sorted most of it.. It's not perfect, but a huge difference. They're gleaming again.
You can clearly see how much grime was inside the headlight. The darker bit is where I wiped my finger accross the inside of the projector lens. I suspect from 15 years of dust and condensation, being heated then cooled repeatedly:
The result is a HUGE difference, along with 2 new bulbs its a large improvement not only in looks but increased light output.
The front of the car, along with both fog lights cleaned and ventilated with drill holes. It looks new.
Bumper off:
Operating table:
Meds 3.0si Coupe
Some little fiddly jobs completed recently.
MOT - Pass.
Fixed rattling door lock pin thingys.
Fixed rattling centre vent, how much of a PITA was it to remove that vent!!??!!!!
Replaced the cold blue LED in the roof light. With this guy: https://shop.bmw.co.uk/4328/genuine-12v ... 7-160-908/ What a great change this has made.
New wheels ordered.
OEM (Suplex) front springs are to be fitted next week. Gone will be the butt clenching and grimacing, yay!
MOT - Pass.
New wheels ordered.
Meds 3.0si Coupe
The front springs were swapped back to OEM (Suplex 06248) height, last week.
I can now drive it without worry, and it's a huge relief.
I've gained 1.25" going back to OEM 'Sport' springs.
The stance is now level, but will change when I get around to doing the rear springs to match.
To bo honest though, the drives I've done so far, it's really hard to notice the difference in spring rates, so I might just leave it for a bit longer and see how it goes. At this point, I cannot notice any difference between front (Suplex) and rear (Eibach Pro).
Before and after:
Before and after:
- 1536Z4
Meds 3.0si Coupe
.........and has Mrs Meds driven it yet Glad it has all worked out ok . Have your new wheels turned up yet ??
