Thank you for all the great information! Much appreciated! Looking forward to this brake project )Player 1 wrote: Tue Feb 12, 2019 9:48 am Regarding brackets, the guys in Belguim made up a CAD drawing of each one, 3D printed them to test fit before having a set properly machined.
Everyone else I've seen has done something similar to that and was something I looked into before selling the set I had, possible there's a small market there? You will also have to check your inner wheel diameter as some 19'' wheels won't clear the 400mm disc/caliper!
This is the Russian car I meant earlier;
https://www.drive2.com/r/bmw/z4/915819/
M5 M6 brakes on Z4 --conversion?
- Valor1
- Jembo
Interesting thread & earlier opinions, great exploration, especially the division of opinion whether it’s truly beneficial for a road car where I believe those against aren’t considering one area of (to me) massive benefit.
I often drive on German Autobhans, where you need to be constantly on your guard for a rapid ‘shave’ of speed.
It’s the amount of ‘leg/foot’ pressure that’s key, regardless whether it’s a rapid UK 70-30 deceleration or DE big +100’s stomach churner.
On the two ‘little league’ brake upgrades I’ve done, to me it’s the greater & more effortless speed shaving that makes such a difference... where you exert far less braking pressure for the same effect...meaning you remain in greater control of the car
Lifer 54
Lifer 54
Onlinebuzyg
Not sure that I agree completely with you there. Fitting larger brakes to a car without changing the OEM suspension set up is very unlikely, to improve the handling/contol of the car, in any way. However the small loss in handling is more than made up for by the increase in safety and driver confidence, due to knowing you can probably stop quicker than the guy in front. So the feeling of control is certainly improved.Jembo wrote: Fri Apr 05, 2019 8:08 am Interesting thread & earlier opinions, great exploration, especially the division of opinion whether it’s truly beneficial for a road car where I believe those against aren’t considering one area of (to me) massive benefit.
- Jembo
The debate will no doubt rage on... last one I did was my old 3.0SE with the 330i calliper upgrade, though had poly’d & billy’d most of it before they went on.buzyg wrote: Fri Apr 05, 2019 8:49 am Not sure that I agree completely with you there. Fitting larger brakes to a car without changing the OEM suspension set up is very unlikely, to improve the handling/contol of the car, in any way. However the small loss in handling is more than made up for by the increase in safety and driver confidence, due to knowing you can probably stop quicker than the guy in front. So the feeling of control is certainly improved.![]()
Likely new discs & pads always help, made for a more relaxed drive - not bothering with the M as they’re fairly new & for road use, their bite is pretty aggressive, noticibly more than the dinner plates on my Merc & u don’t want to be too close behind that on a full stop
I
Lifer 54
Lifer 54
- Player 1
No problem at all, will be looking forward to seeing what you can do!Valor1 wrote: Fri Apr 05, 2019 2:21 amThank you for all the great information! Much appreciated! Looking forward to this brake project )Player 1 wrote: Tue Feb 12, 2019 9:48 am Regarding brackets, the guys in Belguim made up a CAD drawing of each one, 3D printed them to test fit before having a set properly machined.
For reference, I recently had a day in the new G29 Z4 with the four piston front calipers and two piston rears. The brakes on that car felt almost identical to the M4 calipers on mine, a test drive in the new car will give you a very good idea of what I've done will feel like.
- Valor1
Thanks. Be nice to drive the Z4 E89 and G29 back to back. As the steel brakes from the M5 fit I'm thinking better option to keep weight down is to go with the carbon ceramic M5/6 brakesPlayer 1 wrote: Fri Apr 05, 2019 2:21 pmNo problem at all, will be looking forward to seeing what you can do!Valor1 wrote: Fri Apr 05, 2019 2:21 amThank you for all the great information! Much appreciated! Looking forward to this brake project )Player 1 wrote: Tue Feb 12, 2019 9:48 am Regarding brackets, the guys in Belguim made up a CAD drawing of each one, 3D printed them to test fit before having a set properly machined.
Too much focus on the brakes as the primary stopping mechanism, what about the tyres?
Lets not forget the larger tyre footprint of the M card combined with greater weight matches the braking power.
Once you mess with this you destroy the balance built in by the manufacturer so careful consideration is needed.
Like fitting wider tyres, the weight of the vehicle across the tread is reduced by the larger area so less downforce to get grip in the wet!!
just a thought..
just a thought..
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Jembo
mcbutler wrote: Wed Apr 10, 2019 6:11 pm Too much focus on the brakes as the primary stopping mechanism, what about the tyres?
just a thought..
Quality tyres & knackered shocks are just as dangerous.... as are cracked springs, arbs & worn bushes....so many things.
Certainly a bigger picture consideration
Lifer 54
Lifer 54
Agreed..Jembo wrote: Wed Apr 10, 2019 6:35 pmmcbutler wrote: Wed Apr 10, 2019 6:11 pm Too much focus on the brakes as the primary stopping mechanism, what about the tyres?
just a thought..
Certainly a bigger picture consideration, though IMO easier to follow any thread if remains on topic
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Player 1
That'd be an excellent setup if you can get it all together! I didn't do any weighing but the M5 calipers I had felt marginally heavier than the standard Z4 calipers which themselves were noticeably heavier than the M4 calipers.Valor1 wrote: Wed Apr 10, 2019 4:57 amThanks. Be nice to drive the Z4 E89 and G29 back to back. As the steel brakes from the M5 fit I'm thinking better option to keep weight down is to go with the carbon ceramic M5/6 brakesPlayer 1 wrote: Fri Apr 05, 2019 2:21 pmNo problem at all, will be looking forward to seeing what you can do!Valor1 wrote: Fri Apr 05, 2019 2:21 am Thank you for all the great information! Much appreciated! Looking forward to this brake project )
For reference, I recently had a day in the new G29 Z4 with the four piston front calipers and two piston rears. The brakes on that car felt almost identical to the M4 calipers on mine, a test drive in the new car will give you a very good idea of what I've done will feel like.![]()
