Sat Nav Retrofit Fitting Details
half
Re: Sat Nav Retrofit Fitting Details
Post by half » Thu Mar 13, 2014 4:22 pm
Great!
srhutch
Moderator
Moderator
Post by srhutch » Thu Mar 13, 2014 8:27 pm
ESP wrote:I plan on doing this mod,
I have a 07plate 2.0i, with NO cd changer... Will this be a issue ?
No issue if you can find all the parts.
Johncs
Post by Johncs » Mon Oct 13, 2014 8:49 pm
Hello, i bought from ebay the monitor in a very good price... And i want to test it if it is working! Do u know how? I have a z4 facelift but the monitor is from the first 2003 models! Do u know if this is a problem? Its necessary the other parts to be from the same years? ex.( The cid and the mk4)? Thank you!!!
srhutch
Moderator
Moderator
Post by srhutch » Mon Oct 13, 2014 9:02 pm
All the parts should be compatible. Only way to test though is with all the parts I think unless somebody tries it in their car for you.
pvr
Post by pvr » Mon Oct 13, 2014 9:19 pm
You need the computer at least, that is how I tested my original one.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4M Midnight Blue
VW ID.3
Previous:
Z4 3.0 SI black sapphire
Z4 3.0 Toledo
Johncs
Post by Johncs » Mon Oct 13, 2014 9:34 pm
Thanks for the answer!!! Compatible??? There are differences between mk4 or cdi's! Also! Any ideas were i can found the wiring??? I have the gps antenna!
pvr
Post by pvr » Mon Oct 13, 2014 9:40 pm
You can not buy the wire loom anymore, you would have to get the X3 wire loom and slightly modify it to fit for the Z4.
MKIV is the best computer which works with DVD, the MK3 version (CD) is technically possible but OEM never came with it.
Current:
Abarth 595 Comp.
Z4M Midnight Blue
VW ID.3
Previous:
Z4 3.0 Toledo
Johncs
Post by Johncs » Sun Dec 28, 2014 8:53 pm
Hey do you know where i connect the other two small cables that monitor has? please help...
jan_tekin
Post by jan_tekin » Wed Feb 18, 2015 11:29 pm
Ok Ive stated collecting parts for some reason, so fair I've brought a CID radio and a screen. :D
Started to look at sourcing a X3 loom but it looks prices have gone up, dealers are around £200 now and apparently theres just one left in the UK. There is one on eBay buts its used for £120
http://www.ebay.co.uk/itm/BMW-X3-E83-SA ... 1588971804?
is it worth risking buying a used loom :(
I was planing to get this done for around £600 all in but not sure thats possible now
Current: M135i
Sold:3.0lsi Sport Roadster, Xenons,Heated seats, blutooth, Hi Fi,Comfort Pack, Cruse Control, Stormworks ST1
Gear Knob, Stubby, KW V2s, 224s
srhutch
Moderator
Moderator
Post by srhutch » Thu Feb 19, 2015 12:14 am
There's more there than just the nav loom. Looks like the audio loom to. I would go with the eBay one and check the loom continuity before fitting, but can't really see any issues.
jan_tekin
Post by jan_tekin » Thu Feb 19, 2015 12:30 am
srhutch wrote:There's more there than just the nav loom. Looks like the audio loom to. I would go with the eBay one and check the loom continuity before fitting, but can't really see any issues.
thought it looked like a a lot of wires just waiting for a few more quotes
Current: M135i
Bad_Pritt
Post by Bad_Pritt » Sun Mar 15, 2015 9:29 am
Hey guys, where did you get the cutting template from? I'm considering a similar mod and I have all the parts, except the cutting template :-)
I want to make sure I have the right one with the indication for the screw holes at the back!
McKoval
Post by McKoval » Thu Apr 02, 2015 4:27 pm
I am also considering retrofitting a nav, as it happens that I can probably buy CID and HU for more less 200quid
but I cant really find the loom anywhere - is it possible that my 06 3.0si is prewired or I need the loom desperately?
srhutch
Moderator
Moderator
Post by srhutch » Thu Apr 02, 2015 7:21 pm
Loom wont exist, you can modify one from an X3 or find a used one. Both myself and PVR made our own templates using the monitors as guides.
Dougers
Post by Dougers » Sun Nov 08, 2015 2:54 pm
I am a "newbie"- recent owner of an 04 plate Z4; I am not skilled enough to install a sat nav / blue tooth device- suggestions on best/ most economical place to have this done? Thanks.
