Sat Nav Retrofit Fitting Details
Krazee K
Re: Sat Nav Retrofit Fitting Details
Post by Krazee K » Fri Oct 19, 2012 8:33 am
Srhutch, thanks very much for your help mate.
MK3 drives are still around £200 on eBay so its looking like this would work out to be quite a lot on money so not sure its worth it for the business sat nav.
Say I ignored my own commonsense for it anyway does the business nav have the dsp settings and is it just plug and play?
Thanks again.
Krazee K
Post by Krazee K » Fri Oct 19, 2012 6:45 pm
Also...I have found a Mk 3 Navi Box (Part Number 6920758) so will this work with the Business Sat Nav (Part Number 6512 6932442-01) and if so, what wiring harness would I need?
Thanks!
aznoo1
Post by aznoo1 » Sun Oct 21, 2012 5:11 pm
i checked the fuses, and all of them aren't broken for the radio. I guess i have to look for the connection for the power to the gps system. Anyone have a diagram of which pin supplies power to the radio so i can follow the wire.
ColinP
Post by ColinP » Sun Oct 21, 2012 5:44 pm
aznoo1 wrote:i checked the fuses, and all of them aren't broken for the radio. I guess i have to look for the connection for the power to the gps system. Anyone have a diagram of which pin supplies power to the radio so i can follow the wire.
See link for Radio pin location for wires http://www.z4-forum.com/forum/viewtopic ... 30#p237084
jonah1237
Post by jonah1237 » Tue Nov 27, 2012 8:32 pm
Where did you get sat nav and cost ,can't find anything suitable :(
pvr
Post by pvr » Tue Nov 27, 2012 9:26 pm
Mostly from eBay, but not from just the UK. Include Germany and US in the search as my radio came form the US and the screen from Germany.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4M Midnight Blue
VW ID.3
Previous:
Z4 3.0 SI black sapphire
Z4 3.0 Toledo
srhutch
Moderator
Moderator
Post by srhutch » Tue Nov 27, 2012 11:28 pm
From memory my screen was from Greece (eBay)
ranski
Post by ranski » Tue Nov 27, 2012 11:35 pm
Z4 3.0 / Mods done... too many to mention
srhutch
Moderator
Moderator
Post by srhutch » Wed Nov 28, 2012 12:01 am
Very expensive and no loom either.
FAARN
Post by FAARN » Thu Apr 25, 2013 6:55 pm
Bad_Pritt wrote:And yet another question :D
Does anyone have the dimensions (incl depth in the dash) of the standard satnav flip up/down monitor? Are the dimensions of this monitor the same as the dimensions of the X3-monitor? I have read on a few posts here that the parts look alike and that some have even received X3 parts in error when installing the standard satnav. So if the dimensions are the same... the X3 dash bin should fit the E85... hence the portable BMW Garmin system should fit the E85...?
Bad_Pritt, did you ever have joy with your custom Nav fit?
skeme wrote:I too would like to get the plastic assembly and wiring, but not too fussed with the screen inside - Does anyone know if you can get the part without the display in it.
Can anyone confirm the full screen size (width and height) in mm as I will be looking to make my own android incar system.
Can anyone help in sourcing this part? What sort of price is it and where is the best place to get it from?
skeme, did you make a custom android fit?
Looking at parts of eBay the cost seems to have gone up and a custom unit inside a dash tray or Nav Screen would be ideal.
FAARN
Post by FAARN » Sat Apr 27, 2013 5:19 pm
I'm guessing no one had luck with a custom fit. Having searched I am confused about possible set ups. Can I use a Business Navigation System with a MKIV unit and screen as per a pic on this thread? Will this give the same functions as the Professional Navigation System?
srhutch
Moderator
Moderator
Post by srhutch » Sat Apr 27, 2013 6:51 pm
FAARN wrote:I'm guessing no one had luck with a custom fit. Having searched I am confused about possible set ups. Can I use a Business Navigation System with a MKIV unit and screen as per a pic on this thread? Will this give the same functions as the Professional Navigation System?
I wouldnt think so as the business one has its own screen.
FAARN
Post by FAARN » Sat Apr 27, 2013 7:04 pm
Thanks for the reply, looks like I will keep waiting!! Thanks also for the advice about finding the loom first, may have to get an X3 one and adapt it. :D
srhutch
Moderator
Moderator
Post by srhutch » Sat Apr 27, 2013 8:15 pm
Somebody else on here adapted an X3 loom so def possible. Can't remember if he posted full details or not.
ESP
Post by ESP » Thu Jun 27, 2013 11:14 pm
I plan on doing this mod,
I have a 07plate 2.0i, with NO cd changer... Will this be a issue ?
07 Sapphire Black Roadster.
