Hello all.
I recently purchased Z4Pilots old Montego Coupe from the guy he sold it to, Rich.
Rich advertised his Coupe on here and everything fell into place quite well.
It was the spec I was after (bright colour with a contrast interior and a documented history.)
It was fairly local and a sensible price, too.
Latest:
Initial observations (bad points, if you wish):
Oil filter/cooler gasket is a little weepy. DONE
I want to swap out the wheels for 18's, most probably standard Mv2's, 203's or maybe some Riva DTM CSLs. DONE
The carbon lip boot spoiler is not to my tastes, that will be removed. DONE
Replace the aftermarket stero with the original. DONE
Replace the black grills with the originals. DONE
The Koni Yellow adjustable dampers and Eibach Pro springs work really well.. But..... I get arch liner rub on deep road undulations. I need to address this ASAP as it's really, REALLY frustrating! Changing back to OEM springs should sort. DONE
Front bonnet badge is peeling and scruffy. DONE
A teeeny tiny bubble has formed at the bottom of the drivers rear wing, it's very small, but there. DONE
Water pump, thermostat and Micky Mouse flange need doing, preventative. DONE
Headlight perspex needs a polish and seal, a little cloudy on the top edge. DONE
The 2nd key is playing silly beggers, sometimes it works, sometimes not. DONE
2 flickering interior LED bulbs. DONE
Oil service. DONE
Ohh and, I need to build a car port.! DONE
Plus points:
Rocker cover gasket is dry, no leaks.
Rear boot lid is corrosion free.
She runs very well, no apparent issues, smooth idle and pulls nice.
No lifter tick, no DISA rattle.
The Eisenmann quad exhaust is a great visual upgrade and doesn't sound obnoxious at all. Just right. I really like it.
Overall the body work condition is very good. Its obviously been looked after, no swirls or any nasty dings. As is the interior, excellent.
---- Running log ----
Sep 2023 - Rear spoiler removed
Sep 2023 - Washer bottle and pipes de-molded
Oct 2023 - Waterpump, thermostat, flange, oil service and engine flush
Oct 2023 - Front emblem replaced
Oct 2023 - Headlight refurbishment round 1
Nov 2023 - Full rear sound insulation
Nov 2023 - Front xenon bulbs replaced
Nov 2023 - Headlight refurbishment round 2
Nov 2023 - MOT pass 0 advisories
Nov 2023 - Small jobs - Door pins, centre vent, interior bulbs
Dec 2023 - Front springs and tracking
Dec 2023 - Spare key battery and pairing
Dec 2023 - Style 230 wheels replaced with Style 261 and spacers, fresh Falken FK520
Jan 2024 - Door speakers and door insulation
Jan 2024 - Fog light blank install
Feb 2024 - Oil cooler filter gasket, auxilary belt including pully and tensioner
Feb 2024 - Front Brembo 6 piston calipers and E46 CSL discs
Mar 2024 - Coding - Halo DRLs, rear LED DRLs, window operation, 1 touch indicators, indicator blink on unlock
May 2024 - Exhaust manifold-centre section bolts and gaskets replaced
May 2024 - Drivers rear arch replace with genuine new
May 2024 - Drivers sill and front arch removal, rub down, treat and protect
May 2024 - Front reflector colour code
May 2024 - Rear plate LED replace
Jun 2024 - Fog light re-install
July 2024 - Passenger side sill and both arches. Rub down, treat and protect
Sep 2024 - Brake fluid and pressure bleed
Oct 2024 - Sport button 'remember' module install
Nov 2024 - MOT pass 0 advisories
Jan 2025 - Style 405m wheels, refurbished in BMW Ferric Grey A80
Mar 2025 - BDS intake elbow, ITG closed airbox and foam filter install
May 2025 - Replaced satin grill slats with gloss black, keeping chrome surround
May 2025 - Engine bay tidy, paint, new screws/bolts and headlight warning stickers
May 2025 - Steering wheel and rear caliper refurbish
June 2025 - Seat belts change to blue
June 2025 - ZedNation - 2nd place - Best in show comptition
Latest:
Oil service. DONE
Plus points:
