+1 on crashing noises when leaving the bat-caveLeeZ4MR wrote:Smartbear wrote:
If you had a long enough extension lead this method could also let you drive to the local shops without disconnecting the charger![]()
Regards![]()
I used to forget mine was plugged in!and on a few occasions I have driven out of the garage and ripped the cables apart but luckily each time I managed to fix the connections without too much of an issue.
I now hang a red cloth on the drivers door mirror as a reminder when the ctek is fitted
