You can only get 5 on the OEM BMW map DVD. However, there are (illegal) copies around that have added 7 digit post code as Point of Interest on the map.
You can buy this "modified" map from various sources on eBay, however note that a) it is an illegal copy and b) it is a pain to use
dealer nav upgrade - success (eventually)
- pvr
Re: dealer nav upgrade - success (eventually)
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
OnlineStreet
The instructions on how to use it are here:
http://tinyurl.com/5u8v8k (This is a pdf document)
All the UK postcodes have been listed as a point of interest. You search through the POI's like you might if you need a service station etc etc..
When you find the Postcode / POI you need you can select it as your final destination.
As I said before you will need a modified Map disc for this to work though.
3.0si Coupe Sapphire Black Target 300k miles
3.0si Coupe Sapphire Black Why have 1 when you could have 2!!
Serial Zed tinkerer. Always looking for the next Zed project
