A
Anonymous
Guest
HI, I know this topic appears to be talked about to death but I can't find my symptoms out there, so if anyone can help....
1/ Roof is in fully open position and locked. I press the button and it raises about 2/3rds the way then stops (i.e. 1/3rd open). Red light on dash flashes. Pressing any button does nothing and all appears locked. (OK who's the first to shout 'water in the pump!'
2/ Use manual release for hydraulics and let it fall to the closed position. Reset manual release and try to finish closing the roof, no movement. So I allen key it closed and the red light on the dash still flashes at me
3/ Well I thought OK, maybe it's the pump, so I manual released the roof, and opened it up so it rested in the open position. I then tried the button to finish opening it and it worked locking it fully open. So thought maybe I could close the roof and I pressed the button and again the motor worked
but then got stuck about 2/3rds closed again
4/ So this time I thought I'd play a little. With the roof somewhere between 1/3rd and fully open the motor works and it will lock the roof into the open position fine. I could open/close/open close until the cows come home so long as I don't close it more than half way. But, as soon as it moves towards the closed position it stops and the roof is left slightly open and no buttons work.
All this sings to me that it is a sensor, or a computer issue (also consider wiring but as it is really consistent in where it decides to suddenly stop I can probably rule this out) .......
I was really hoping one of you smart guys out there could shed some light on the fault and specifically where to look.
(Oh, and just to make certain, these tests were carried out with the car running (so no battery issues) and the parcel shelf in the down position (no amber light showing on the dash!)
Fill your boots and lets see who can come up with the first sensible solution that isn't the pump sitting in water
