pilchardthecat's MAF screen mod
Re: pilchardthecat's MAF screen mod
Couldnt u just drill holes in exis airbox,
So far i've decatted and just took the outer mesh screen off the maf .its got a bit more noise with no loss if power/fuel consuption.but seems a little more free reving..
Gonna look at taking some of the packing out of the muffler next .slowly slowly.want a bit more noise but not too much .
M
Sent from my GT-I9300 using Tapatalk 2
M
- exdos
Modding the exhaust alone gave me no gains. It was only after doing my Eureka air-intake mod that I got any gains. But once I'd done the Eureka mod, doing further intake mods, coupled with my exhaust gutting mod, yielded further gains. Only from datalogging can you see what works and what doesn't, and the total gain is the aggregate sum of a collection of mods working in conjunction with each other.Z4M-2006 wrote:How much do you think the exhaust hinders if you do all the intake mods..?
I quite like the exhaust sound as it is..
- exdos
AlienZed wrote:Couldnt u just drill holes in exis airbox,
- jimmybell
interesting mods! need to get hold of a spare air box lid
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
- exdos
You could've just cut away all the plastic beneath the CF skin and left a margin to bond the CF skin to the plastic lid. In essence you've used the sonorous properties of CF to get an induction noise in the same way that the front of a violin is made of quarter-sawn spruce for its sonorous quality, whilst the back is made from maple for its sound-reflective quality.pilchardthecat wrote:This is my cheapo induction noise mod.
You should manufacture the part.
exdos wrote:Modding the exhaust alone gave me no gains. It was only after doing my Eureka air-intake mod that I got any gains. But once I'd done the Eureka mod, doing further intake mods, coupled with my exhaust gutting mod, yielded further gains. Only from datalogging can you see what works and what doesn't, and the total gain is the aggregate sum of a collection of mods working in conjunction with each other.Z4M-2006 wrote:How much do you think the exhaust hinders if you do all the intake mods..?
Thanks...
I have emailed you about the "eureka" mod btw...
My intention was to cut the whole section away yes, but my saw gave out and so I resorted to drilling big holes. This one was only supposed to be a temporary experiment to see if making a complete cf airbox would be worthwhile so it was a bit of a hack job - I never expected it to stay on the car really, but it worked so well I left itexdos wrote:You could've just cut away all the plastic beneath the CF skin and left a margin to bond the CF skin to the plastic lid. In essence you've used the sonorous properties of CF to get an induction noise in the same way that the front of a violin is made of quarter-sawn spruce for its sonorous quality, whilst the back is made from maple for its sound-reflective quality.pilchardthecat wrote:This is my cheapo induction noise mod.
I used just a couple of layers of cf and 3 of resin so it is very very light and thin, lots of nice noises get out
Z4M Roadster.
I would love to get these mods before I get the remap done.
You fancy doing this pour moi...pretty please??
Tiko
Tiko
Really interesting mod, does it still seal as per the original for the ram effect? More noise must mean less pressure?pilchardthecat wrote:My intention was to cut the whole section away yes, but my saw gave out and so I resorted to drilling big holes. This one was only supposed to be a temporary experiment to see if making a complete cf airbox would be worthwhile so it was a bit of a hack job - I never expected it to stay on the car really, but it worked so well I left itexdos wrote:You could've just cut away all the plastic beneath the CF skin and left a margin to bond the CF skin to the plastic lid. In essence you've used the sonorous properties of CF to get an induction noise in the same way that the front of a violin is made of quarter-sawn spruce for its sonorous quality, whilst the back is made from maple for its sound-reflective quality.pilchardthecat wrote:This is my cheapo induction noise mod.
Where did you get the cf sheets from?
If I've undrstood it correctly, any holes are covered back up. The extra noise comes from having thinner material (the carbon fibre) ather than the thicker plastic.daz05 wrote: Really interesting mod, does it still seal as per the original for the ram effect? More noise must mean less pressure?
Yes, it's completely air tight and sealed - easy to check, just push it under a sink full of water and check for bubbles
Z4M Roadster.
As exdos said, the airbox is pressurised by the ram air system, and overall it is very well designed - you do not want to leave holes as this will reduce the pressure. There are some things you can do to increase the pressure and/or retain more of it/reduce losses - this is what exdos and myself have been messing about withAlienZed wrote:Couldnt u just drill holes in exis airbox,
M
Also, it's not a good idea to remove the mesh from the maf screen and just leave the plastic air straightener - the plastic alone does a poor job of inducing laminar flow (there is a reason they stuck the mesh on there). You need both, or something that fulfills both functions as per my mod. You might not have noticed it, but there will be points in the rev/speed range where you will have turbulence around the maf, and the mix will be off
Z4M Roadster.
True, nice idea, a tidier version would sell I'm sure. Applicable to all the M cars too.pilchardthecat wrote:Yes, it's completely air tight and sealed - easy to check, just push it under a sink full of water and check for bubbles
Thanks for the info guys starting to understand wot your both aiming to achieve, your tech knowledge is great.
Well done.
Just off for a blast round the peak dist then put Zeddy to bed for 10 days.
Off to Salou on tues so i'll start again when we get back.
Cheers Moz
Well done.
Cheers Moz
I may spot you then
