///M troubles
- Curtis
- enfield
Re: ///M troubles
There will be no V8. pvr bought an I-6 Z4M.Wondermike wrote:Unbelievable, the amount of problems on this thread. It's like the engine starts tearing the car apart or something - lets hope the new V8 doesn't make it into the Z4 - at this rate it will fall apart.
The Z4M Roaster & Croup are gone!
It's E92 M3 from now on.
- senwar
- zee42
- Location: I could tell you,But then I'd have to kill you!!
Curtis wrote:I've had too many to list as members of a certain defunkt forum will know. Most worrying of all though was breaking the welds on my bulkhead/firewall. Before you say anything Zee it was nothing to do with the way I drive it. Not much anyway.
What about that time you tried to jump the English channel?????????
and then theres that skate board ramp thing
- sixspeed
Picked the car up after it's Oil service today (and £240 lighter ) and had mentioned the fault list to them when I dropped it off. They cured the creaking/rattle. Sure enough, engine bracing arms were the culprits!JayD wrote:Andy,sixspeed wrote: Rattle/light knock from behind dash/back of engine bay.
You sure its not the bracing arms that need tightening in the engine bay? They are known to come loose and need tightening from time to time.
- Gauss
Your car is white right. Are you painting that carbon fiber roof? If not, what if it comes out looking bad? Can you remove it?sixspeed wrote:Picked the car up after it's Oil service today (and £240 lighter ) and had mentioned the fault list to them when I dropped it off. They cured the creaking/rattle. Sure enough, engine bracing arms were the culprits!JayD wrote:Andy,sixspeed wrote: Rattle/light knock from behind dash/back of engine bay.
- sixspeed
Yes, I can remove it. Or paint it. But it won't look bad. So there.Gauss wrote:Your car is white right. Are you painting that carbon fiber roof? If not, what if it comes out looking bad? Can you remove it?sixspeed wrote:Picked the car up after it's Oil service today (and £240 lighter ) and had mentioned the fault list to them when I dropped it off. They cured the creaking/rattle. Sure enough, engine bracing arms were the culprits!JayD wrote:
Andy,
