Handbrake woes
Ilogik
Handbrake woes
Post by Ilogik » Wed Jun 18, 2025 1:59 pm
Do you have a pic? I think mine looked ok when I check, its the thing that has a nipple coming out of one side right that should be all the way in so it looks like there's a hole one side?
enuff_zed wrote: Sun Jun 15, 2025 10:12 am
Ilogik wrote: Sat Jun 14, 2025 2:32 pm Considering just selling it as it is, repair with parts I’m now looking at around £600 if it 100% fixes it if it is the part.
Pulling hand brake all the way up today, must’ve clocked about 8 times but it was holding it now which is weird.
Ah, I've had that a couple of times. There's a spring and tab under the lever which you are supposed to engage to take tension off the cable when you're adjusting it. On both occasions for me that tab was engaging every now and then and of course making the cable go slack. I assume something gets weak in there?
If it happens again, don't move anything, whip up the gaiter and see if the tab has engaged with the slotted disc at the end of the spring. If so, ping it back with a screwdriver.
enuff_zed
Handbrake woes
Post by enuff_zed » Wed Jun 18, 2025 2:39 pm
Ilogik wrote: Wed Jun 18, 2025 1:59 pm Do you have a pic? I think mine looked ok when I check, its the thing that has a nipple coming out of one side right that should be all the way in so it looks like there's a hole one side?
This link should show it clearly for you.
https://www.pelicanparts.com/techarticl ... usting.htm
HQ of 'Norfolk Zed Rescue'.
Jollygiant
Handbrake woes
Post by Jollygiant » Wed Jun 18, 2025 4:49 pm
When I adjusted mine a couple of weeks ago I just did it though the hole on the hub and did it until it wouldn’t move, wheels on let it down tried to pull away with handbrake on it stalled, so I guess I did it ok.
Ilogik
Handbrake woes
Post by Ilogik » Fri Jun 20, 2025 10:11 am
Jollygiant wrote: Wed Jun 18, 2025 4:49 pm When I adjusted mine a couple of weeks ago I just did it though the hole on the hub and did it until it wouldn’t move, wheels on let it down tried to pull away with handbrake on it stalled, so I guess I did it ok.
how high up was your hand brake going up pre tightening.
Jollygiant
Handbrake woes
Post by Jollygiant » Fri Jun 20, 2025 10:50 am
Ilogik wrote: Fri Jun 20, 2025 10:11 am how high up was your hand brake going up pre tightening.
It was quite high and the teeth were worn and only the first two worked, so just adjusted up for those and I got it good enough to pass the MOT two weeks ago.
