Project Restoration Zed- Final stages
- pvr
Project Zed is here
I read it back and could see what you thought
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Calps
Project Zed is here
How bad is the front bumper? Is it rescue-able (or worth rescuing)?
MelZ: Black Sapphire Z4C
- paddy wright
Project Zed is here
It’s sadly passed it’s best- I will keep it to see if I can do anything with it as a project once the car is finished.
- paddy wright
Project Zed is here- help please
So having some time today to play with the project it seems the lights aren’t working correctly. The lights are auto headlights. The lights come on as soon as the car starts but you can’t turn them off or indicate or use main beam. Is this the LCM? Carpets under both seats are a bit damp too- could this be linked? No fuses are blown.
Onlinebigwinn
I’d say lcmpaddy wright wrote: ↑Sat Nov 18, 2023 9:44 pm So having some time today to play with the project it seems the lights aren’t working correctly. The lights are auto headlights. The lights come on as soon as the car starts but you can’t turn them off or indicate or use main beam. Is this the LCM? Carpets under both seats are a bit damp too- could this be linked? No fuses are blown.
I’ve got a load of spares if you need to borrow one to test it? Which lcm is it? Auto/xenon etc?
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- paddy wright
Auto non xenon. That would be amazing! Is it right that swapping the LCM will throw a tamper spot?bigwinn wrote: ↑Sat Nov 18, 2023 9:59 pmI’d say lcmpaddy wright wrote: ↑Sat Nov 18, 2023 9:44 pm So having some time today to play with the project it seems the lights aren’t working correctly. The lights are auto headlights. The lights come on as soon as the car starts but you can’t turn them off or indicate or use main beam. Is this the LCM? Carpets under both seats are a bit damp too- could this be linked? No fuses are blown.
- enuff_zed
Yes but won’t hurt for a diagnostic swappaddy wright wrote: ↑Sat Nov 18, 2023 10:19 pmAuto non xenon. That would be amazing! Is it right that swapping the LCM will throw a tamper spot?bigwinn wrote: ↑Sat Nov 18, 2023 9:59 pmI’d say lcmpaddy wright wrote: ↑Sat Nov 18, 2023 9:44 pm So having some time today to play with the project it seems the lights aren’t working correctly. The lights are auto headlights. The lights come on as soon as the car starts but you can’t turn them off or indicate or use main beam. Is this the LCM? Carpets under both seats are a bit damp too- could this be linked? No fuses are blown.
Onlinebigwinn
It will but will go when you put your lcm backpaddy wright wrote: ↑Sat Nov 18, 2023 10:19 pmAuto non xenon. That would be amazing! Is it right that swapping the LCM will throw a tamper spot?bigwinn wrote: ↑Sat Nov 18, 2023 9:59 pmI’d say lcmpaddy wright wrote: ↑Sat Nov 18, 2023 9:44 pm So having some time today to play with the project it seems the lights aren’t working correctly. The lights are auto headlights. The lights come on as soon as the car starts but you can’t turn them off or indicate or use main beam. Is this the LCM? Carpets under both seats are a bit damp too- could this be linked? No fuses are blown.
Pm me your address I’ll pop one in the post
EWS Delete PM me
EWS Delete PM me
- paddy wright
Thanks so muchbigwinn wrote: ↑Sat Nov 18, 2023 10:58 pmIt will but will go when you put your lcm backpaddy wright wrote: ↑Sat Nov 18, 2023 10:19 pmAuto non xenon. That would be amazing! Is it right that swapping the LCM will throw a tamper spot?
- paddy wright
Loaned LCM fitted- lights all fixed and working perfectly
- pvr
Excellent result. That loan library came in very handy
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
So are you keeping that in and getting it coded to prevent the tamper dot?paddy wright wrote: ↑Sat Nov 25, 2023 2:35 pm Loaned LCM fitted- lights all fixed and working perfectly
Be aware that if you do a lot of miles before you get it coded then somewhere deep in the memory banks it will always show that there is a discrepancy. ie. It will show that it thinks it had the wrong LCM in for all those miles.
- paddy wright
I need to ask Bigwinn what he would like to do- ideally yes I’ll buy this and then see if someone can code it.enuff_zed wrote: ↑Sat Nov 25, 2023 2:42 pmSo are you keeping that in and getting it coded to prevent the tamper dot?paddy wright wrote: ↑Sat Nov 25, 2023 2:35 pm Loaned LCM fitted- lights all fixed and working perfectly
I’m into taking the seat out now to try and see if there’s a reason the carpets wet underneath- I think it’s been the door membrane that’s leaked and been replaced and just left over moisture in the foam in the floor. Can’t figure out how to take the seatbelt out of the guide though
- enuff_zed
What seats?paddy wright wrote: ↑Sat Nov 25, 2023 3:14 pmI need to ask Bigwinn what he would like to do- ideally yes I’ll buy this and then see if someone can code it.enuff_zed wrote: ↑Sat Nov 25, 2023 2:42 pmSo are you keeping that in and getting it coded to prevent the tamper dot?paddy wright wrote: ↑Sat Nov 25, 2023 2:35 pm Loaned LCM fitted- lights all fixed and working perfectly
- paddy wright
Standard seats
