Roof broken again, only half closes
Just make sure you mark the bolts on the hinges when you undo them. They need to go back in exactly the same place they came from otherwise the bootlid will be wonky and a world of pain.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- SteveNortham
Grabbed them off a seller on Ebay, £29 - no idea if thats a good price? but for £60 fix then its worth a punt!
![Smile :)](./images/smilies/original.gif)
Msport wrote: ↑Fri May 26, 2023 7:45 pm Sounds just like mine- it's getting more and more frequent now on mine too.
Like you I have also managed to get the roof and windows all back up for now (after trying to run the opening/closing cycle multiple times).
Definitely keep us posted on here as to how you get on fitting your switches - where did you order them, direct from BMW?
SteveNortham wrote: ↑Fri May 26, 2023 7:19 pm Mine was intermittent for a few days but now seems to do it every time, I managed to get it back down and windows up after a few tries and left it like that for now - ill check out the fix thread and see if can solve![]()
- SteveNortham
Thanks for all that, is this the thread you mention;
viewtopic.php?t=95385#p1402669
You have given me the confidence to have a go myself, worst case I can just give the indy it's booked into in a few weeks time the new switches if I order and can't fit myself.
Pondrew wrote: ↑Fri May 26, 2023 7:42 pmClassic symptoms of bootlid microswitches. They do seem to be the most common ones to fail due to internal corrosion (not sure why TBH).SteveNortham wrote: ↑Fri May 26, 2023 7:19 pm Mine was intermittent for a few days but now seems to do it every time, I managed to get it back down and windows up after a few tries and left it like that for now - ill check out the fix thread and see if can solve![]()
There is a really good thread on here on where they are located, and a step-by-step guide to changing them, along with BMW part numbers. I did mine last summer (as had exactly the symptoms described here). It is a very simple job and cheap, as long as you do the right things like marking the bolt positions otherwise everything can go out of whack and it will then be a nightmare.
Sopers of Lincoln BMW (if in the UK) are really good on price for parts, very helpful and give a discount to forum members (usually free postage too IIRC).
No there is another one (or more than one actually as it has been discussed many times) which gives detailed instructions. I seem to remember another thread quite recently (end of last year?) where someone did it and made a youtube video.Msport wrote: ↑Fri May 26, 2023 7:51 pm Thanks for all that, is this the thread you mention;
They will all be in the E89 problems section, or maybe the E89 discussion section.
![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
They were £16 each from BMW when I got mine, so sounds about right. I would check they are genuine BMW parts TBH. Not heard of anyone buying 'pattern' or 'knock off' ones.SteveNortham wrote: ↑Fri May 26, 2023 7:50 pm Grabbed them off a seller on Ebay, £29 - no idea if thats a good price? but for £60 fix then its worth a punt!![]()
Depending on the year of car, they have different connector plugs aswell. I think they changed in 2013 with the facelift.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineOle gits rule
Mine were £16 as well, never seen patterned ones anywherePondrew wrote: ↑Fri May 26, 2023 8:20 pmThey were £16 each from BMW when I got mine, so sounds about right. I would check they are genuine BMW parts TBH. Not heard of anyone buying 'pattern' or 'knock off' ones.SteveNortham wrote: ↑Fri May 26, 2023 7:50 pm Grabbed them off a seller on Ebay, £29 - no idea if thats a good price? but for £60 fix then its worth a punt!![]()
Good luck with the job
M4 Vert in Yas Marina Blue
I think this might be the one you refer to where a video tutorial was made- that's very useful thanks, I'll keep searching for the others:
viewtopic.php?t=137215
Pondrew wrote: ↑Fri May 26, 2023 8:16 pmNo there is another one (or more than one actually as it has been discussed many times) which gives detailed instructions. I seem to remember another thread quite recently (end of last year?) where someone did it and made a youtube video.Msport wrote: ↑Fri May 26, 2023 7:51 pm Thanks for all that, is this the thread you mention;
They will all be in the E89 problems section, or maybe the E89 discussion section.![]()
- SteveNortham
Perfect - ill give this a whirl when parts arrive and report back if it fixes!
Msport wrote: ↑Fri May 26, 2023 9:19 pm I think this might be the one you refer to where a video tutorial was made- that's very useful thanks, I'll keep searching for the others:
That's the fella! Hardest bit of the job I found was finding a suitable piece of wood to hold the boot lid open while doing the work. The hydraulic pressure won't hold for long enough!Msport wrote: ↑Fri May 26, 2023 9:19 pm I think this might be the one you refer to where a video tutorial was made- that's very useful thanks, I'll keep searching for the others:
![Very Happy :D](./images/smilies/biggrin.gif)
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
These roofs are failing big time. Book a road trip to Deutschland and get RobbiZ4 to renew everything en route is the best answer
Here is my video. I used an extension handle for a paint roller.
https://youtube.com/watch?v=qcwZC1uah_o&feature=share8
- z4lincs
Decided to give it a go this afternoon and total success, saved myself a couple of hundred quid there which was what the indy were going to chargeOle gits rule wrote: ↑Thu May 25, 2023 3:48 pmYeah mine was the same - switches were £16 each at that point prob around £25 now, labour was pretty steep on it at 2Hrs then the diagnostics, just glad mine was covered under warranty.z4lincs wrote: ↑Thu May 25, 2023 2:12 pmYeah mine is currently under a cover in exactly the same state with the roof half up.. booked in for replacement micro switches next week to hopefully sort. Was intermittent for a few days and now won't budge.Ole gits rule wrote: ↑Wed May 24, 2023 8:32 pm The battery will cause major issues but by the description it sound like micro switches - I am sure Robbie will be along to give better advice
I think its pretty easy to do - few videos online on how to do it
![Image](https://static.wixstatic.com/media/0163fc_b81a48c6ada7458f87e2475348d4e507~mv2.png)
E89 20i (ish) M Sport Valencia Orange
Gone: E85 2.0i, 2.5si & 3.0i
OnlineOle gits rule
Great news all round - you can now tout for business the way these are failing this yearz4lincs wrote: ↑Sat May 27, 2023 8:24 pmDecided to give it a go this afternoon and total success, saved myself a couple of hundred quid there which was what the indy were going to chargeOle gits rule wrote: ↑Thu May 25, 2023 3:48 pmYeah mine was the same - switches were £16 each at that point prob around £25 now, labour was pretty steep on it at 2Hrs then the diagnostics, just glad mine was covered under warranty.
I think its pretty easy to do - few videos online on how to do it![]()
- SteveNortham
Swapped mine out today, all working as it should again! nice and easy, about an hour I recon to do both sides, had to chop the connector and solder new ones on etc. but a very simple fix thankfully!
The cause seems to be...last summer, when I last washed the car
- it seems water got into the boot, the spongy case for the pump, the bottom was saturated in water, pump was not impacted it seems but being sat for months with water in the boot seems to have caused a nice damp atmosphere in there and corroded the microswitches... lesson learnt, be less abusive with the jet wash and use the car more!
![ROFL :rofl:](./images/smilies/smilie_roflmao2.gif)
- IMG_8279.jpg (349.49 KiB) Viewed 358 times
