Conti sport contact 5 and 6
Alloy wheels and tyre discussion
Pondrew
Post by Pondrew » Sat Nov 19, 2022 1:40 pm
Thanks all for the input.
I have had (yet) another look at sizes, and as Peter suggested I have increased sizes to 275/35/19 and 245/40/19.
These give me much more choice in matching fronts and rears. They are actually generally cheaper too; I'm presuming my 265/35 size is unusual so commands a premium.
I now have a realistic choice of (dearest to cheapest): Conti SC 7, Uniroyal rainsport, or Kumho Ecsta
2024 Audi A4 avant 40 black edition petrol
2025 Ford Focus ST 'track pack'. Go-kart with sat nav.
Z3 'free litre'. Project and a half.
No Z4 anymore!
B21
Post by B21 » Sat Nov 19, 2022 6:34 pm
You will find the 235 front steers more easily / quickly with less tendency to tramline compared with the 245..
The 245 gives more grip in corners when pushed very hard but isn’t as ‘sweet’ overall…FWIW
Both are recommended by Conti for the 8.5J
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
Pondrew
Post by Pondrew » Sat Nov 19, 2022 6:43 pm
B21 wrote: Sat Nov 19, 2022 6:34 pm You will find the 235 front steers more easily / quickly with less tendency to tramline compared with the 245..
The 245 size is purely to give the closest diameter to the 275 TBH, Peter. The combo of these are only 2.5mm difference in diameter. If I go 235 with 275 it goes out by too much for my liking. I would also be back to square one with finding matching tyres.
Just got to hope there is no rubbing anywhere with 245s! :|
No Z4 anymore!
B21
Post by B21 » Sat Nov 19, 2022 6:47 pm
0.5% vs 0.7% is effectively irrelevant from a DSC or speed calibration viewpoint..but that’s your choice..on the E89 245s are very tight…obviously your offset vs OE is a more critical factor..both space and steering response..
Pondrew
Post by Pondrew » Sat Nov 19, 2022 6:59 pm
B21 wrote: Sat Nov 19, 2022 6:47 pm 0.5% vs 0.7% is effectively irrelevant from a DSC or speed calibration viewpoint..but that’s your choice..on the E89 245s are very tight…obviously your offset vs OE is a more critical factor..both space and steering response..
The offset is only 1mm different (35 opposed to 36) and the wheel is 1/2" wider (8.5 opposed to 8 ). Even with an extra 20mm tyre width I think they will be OK TBH.
Thank you for your input and advice Peter. I do appreciate it! :thumbsup:
No Z4 anymore!
plenty
Post by plenty » Sat Nov 19, 2022 7:44 pm
I am currently running 255/35/18 and 225/45/18 on an E85, a 3.8% difference in circumference. Matching rolling radius only matters on an AWD vehicle.
Mr Tidy
Post by Mr Tidy » Sat Nov 19, 2022 9:14 pm
FWIW mr_wilks used to recommend Kumho Ecstas quite often so I had a set fitted to my MC in 2020 and I've been very pleased with them.
I also went up a profile on the rears to 255/45 x 18 instead of 255/40 for a bit more sidewall and that hasn't been a problem - just means the speedo is more accurate!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Pondrew
Post by Pondrew » Sat Nov 19, 2022 9:59 pm
Mr Tidy wrote: Sat Nov 19, 2022 9:14 pm FWIW mr_wilks used to recommend Kumho Ecstas quite often so I had a set fitted to my MC in 2020 and I've been very pleased with them.
Thanks Iain. I am now looking at the Kumhos, Dunlops and Goodyear F1 assy 3.
The Kumhos seem quite a bit cheaper, so will make enquiries on Monday. To be honest I am not looking for 'cutting edge' performance, just decent tyres that will cope with everyday driving on a fairly powerful, heavy RWD car.
Going to need a can of tyre weld too!!
No Z4 anymore!
smorris_12
Post by smorris_12 » Sat Nov 19, 2022 10:03 pm
I had Kuhmos when they were still an unrated budget and was jolly impressed with them for performance. Not as good for mileage as the big names but not a ditch finder.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Pondrew
Post by Pondrew » Sat Nov 19, 2022 10:06 pm
smorris_12 wrote: Sat Nov 19, 2022 10:03 pm I had Kuhmos when they were still an unrated budget and was jolly impressed with them for performance. Not as good for mileage as the big names but not a ditch finder.
Cheers. :thumbsup: Mileage is not really a concern for me (I get slated constantly by certain 'members' for never using my cars). The car in question has done 900 miles in 7 months! :oops:
No Z4 anymore!
smorris_12
Post by smorris_12 » Sat Nov 19, 2022 10:41 pm
Pondrew wrote: Sat Nov 19, 2022 10:06 pm Cheers. :thumbsup: Mileage is not really a concern for me (I get slated constantly by certain 'members' for never using my cars). The car in question has done 900 miles in 7 months! :oops:
Try harder man!
For many years I had no job and no reason to go anywhere much but my E46 would still somehow rack up 14k a year. I assume either someone else had a key or the odo had a built in random number generator. I could add 900 miles by popping out to buy sweets. I've a feeling I went through 230,000 and 240,000 on the same outing.
Scott
Mr Tidy
Post by Mr Tidy » Sat Nov 19, 2022 10:48 pm
Pondrew wrote: Sat Nov 19, 2022 9:59 pm
Just thought it may be useful Andrew.
I find the Ecstas fine even when I am pushing on a bit, and they way superior in cooler damp conditions than the MPSS tyres it came with.
When you get Tyreweld don't forget a compressor!
Gone - Montego Blue
Gone - Ruby Black
Pondrew
Post by Pondrew » Sat Nov 19, 2022 10:58 pm
smorris_12 wrote: Sat Nov 19, 2022 10:41 pm For many years I had no job and no reason to go anywhere much
For many years I did have a job and had to go everywhere much. Now I'm old and don't need to do that, I just don't! :D :poke:
No Z4 anymore!
B21
Post by B21 » Sat Nov 19, 2022 11:25 pm
plenty wrote: Sat Nov 19, 2022 7:44 pm I am currently running 255/35/18 and 225/45/18 on an E85, a 3.8% difference in circumference. Matching rolling radius only matters on an AWD vehicle.
That’s a simple and partially incorrect answer..
Some later cars eg G29 have DSCs that cope with dissimilar rolling radius…as you say XDrive cars often mandate identical rolling radius
However some cars, certainly the E89 do require a degree of matching, typically within 2%..
When I inadvertently had a mismatch of around 4% I had DSC issues with various errors if the car was sliding or had wheels spinning, often the errors only arise when the DSC unit has to step in..
plenty
Post by plenty » Sun Nov 20, 2022 12:59 am
I certainly stand corrected - thank you.
