Z4MR Spring Dilemma
- RvsBmw
Z4MR Spring Dilemma
Hi Andy/All,
I changed my stock springs for eibach on the OEM dempers.
Would do it again, or just go for the KW v3 or other A-class coils.
Why Eibach for me:
- Nice ride height, just OEM+. And not visible lower than "stock" like HR;
- Also comfort is the same or slightly better than oem. People say that HR is stiffer than standard, but i didnt drove a car with OEM dampers + HR.
If needed, i can send you detailed pictures of the ride height with OEM dampers + Eibach springs.
Why Eibach for me:
Current: BMW Z4M Coupe '07 (one-off) | Midnight Blue Metallic | Syrah Blue Leather | OEM CSL's | Aero's
Gone: BMW Z4M Coupe '08 | Sapphire Black | Bicolour Silverstone Anthrazit | OEM CSL's | Aero's
Z4MR Spring Dilemma
I would really appreciate some pics of this.RvsBmw wrote: ↑Tue Jul 27, 2021 3:46 pm Hi Andy/All,
Why Eibach for me:
I ordered a Bilstein B12 pro Kit which comes with 20mm Front and 10mm rear eibach springs.
But it's taking so long from Bilstein on back order I'm thinking about just going for stock shocks with the Eibach springs
Z4MR Spring Dilemma
Would be great to see the differenceRvsBmw wrote: ↑Tue Jul 27, 2021 3:46 pm Hi Andy/All,
Why Eibach for me:
--- Currently - 2007 Z4MR
--- Previous BMWs - Z4 M40i First Edition, Z4 2.5i Sport, 430d xdrive Coupe, 330i Coupe, 525i, 540i, Z4 2.5i, 330ci Convertible, Z3
--- Plus over 40 non BMWs inc. S2000, Focus ST, Octavia VRS, RS3, MINI JCW
- RvsBmw
Z4MR Spring Dilemma
Hi Andy/Brownah,
Will make the pictures this saterday when the car is clean.
Lots of rain, cannot introduce the car here filthy .
- bakes100
Z4MR Spring Dilemma
I assume I am in the minority here but I have the Eibachs fitted to my Z4MC and in my opinion the front springs are too low and too hard, giving very little suspension travel. The rears are perfect in terms of ride height and stiffness.
I will soon be swapping my fronts back to OEM springs with the Bilstein struts.
2006 BMW Z4M Coupe - Sapphire Black
2007 BMW Z4M Coupe - Silver Grey - GONE
- RvsBmw
Z4MR Spring Dilemma
Ah, i dont have that problem in The Netherlands, even with the speedbumps here!bakes100 wrote: ↑Wed Jul 28, 2021 4:28 pm I assume I am in the minority here but I have the Eibachs fitted to my Z4MC and in my opinion the front springs are too low and too hard, giving very little suspension travel. The rears are perfect in terms of ride height and stiffness.
Perhaps if you have a frontsplitter like APR its more of a problem.
- RedUn
Z4MR Spring Dilemma
I'll be the miserable one on here. .. People need to be really careful mixing suspension/springs.
Your seriously affecting the weight distribution of the car which could cause unknown handling affects.
As standard the zed is rear biased, lowering the rear only will only make it worse. 50:50 weight distribution in the zed "looks" nose down.
I know the cars are older and cheaper these days but it's a 165+mph car your messing with here, it's not a toy, be careful we don't want any accidents, there's not many nice ones left
IMOLA Z4///MR
- RvsBmw
Z4MR Spring Dilemma
Trust me the eibach works very well at 165+ . Also eibach isnt that kind of shady company. Even H&R is well known, check out the numberplates in case of a race around the Nürburgring. So no worries there.RedUn wrote: ↑Wed Jul 28, 2021 6:44 pm I'll be the miserable one on here. .. People need to be really careful mixing suspension/springs.
- RedUn
Z4MR Spring Dilemma
Im talking about people mixing oem and aftermarket suspension on different axles.RvsBmw wrote: ↑Wed Jul 28, 2021 7:21 pmTrust me the eibach works very well at 165+ . Also eibach isnt that kind of shady company. Even H&R is well known, check out the numberplates in case of a race around the Nürburgring. So no worries there.RedUn wrote: ↑Wed Jul 28, 2021 6:44 pm I'll be the miserable one on here. .. People need to be really careful mixing suspension/springs.
I know Eibach and H&R very well
IMOLA Z4///MR
- RvsBmw
Z4MR Spring Dilemma
Ah, misunderstanding sorry!
Best to go direct with KW v3 or Cs with a good setup.
- RedUn
Z4MR Spring Dilemma
Indeed but not everyone wants to spend so much hence lots choosing springs or a spring and damper combination.
I think the main thing here is, don't mix these things up
IMOLA Z4///MR
- RvsBmw
Z4MR Spring Dilemma
Hi Andy/All,
See pictures below.
12,5cm/4,9inches ground to front lip (left/right) = lowest point
16cm/6,2inches ground to front lip (middle)
Hope this will help. For me this is how they needed to deliver from factory .
Full side Front Rear Closeup front Closeup Rear Cheers
- RvsBmw
Z4MR Spring Dilemma
See above
Z4MR Spring Dilemma
Yeah odd but, it works on our great pot hole roads over here. Haven’t had a 4 wheel alignment yet, but tracks and handles spot on without the over correction wiggle
HSD are clueless by the way, but the front coil overs work
- tomscott
Z4MR Spring Dilemma
I had H&Rs on my Z4MC the dampers were weeping in no time. It looked good but bottomed out all the time on a-b roads but it was flat and much better than the OEM as my MR feels floaty. I would go the B12 kit route and plan on doing the same with my MR.
BMW Z4M Coupe with CSL wheels by Tom Scott, on Flickr
