I'm thinking the further you place that wheel from the pivot point of the suspension, the more it will compress the spring and the more camber will occur. For example using a shorter lever to compress a spring vs a longer lever.
- 3gGT01
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
Spacers always look silly on a standard height car.
2009 09 Carbon Black Cinnamon E86
- Big Andra
2009 E89 2.5 Alpine white.
2008 cayman 2.7 Arctic silver.
- Calps
Woken from hibernation, taxed & tested for another year and, seeing as roof mounted bike racks are all the rage in the past week, straight into chauffeur duties (however looking forward to some non-ultility based trips in the coming months too).
- 20240413_092030.jpg (201.26 KiB) Viewed 398 times
MelZ: Black Sapphire Z4C
- enuff_zed
Hard to judge from one photo, and I'm a newbie.... but the car looks fine IMHO, and it looks like anywhere in the 0mm to 30mm range would be OK. Personal taste what you actually decide on.
Freshly tinted windows and a good clean… hope the sun stays out..
- IMG_5819.jpeg (191.09 KiB) Viewed 338 times
Today I just gave a bit of a polish to everything under the bonnet!! happy days...
- 20240414_125526.jpg (206.18 KiB) Viewed 317 times
- chanlon1
I’ve done more head scratching than anything.
Removed airbox and pipe work, throttle body out as well. Now trying to work out the physics of how to fit anything let alone hands or tools under the manifold to get to the starter motor…..,
E86 Z4 Coupe 2006 Silver
I don’t care if they do or don’t Martin.
That’s the point of having an opinion
- enuff_zed
Exactly. I like them on my wife's E85 with standard wheels and ride height.
- Barty
Personally, faffing about trying to get access takes about as long as pulling the manifold, so might as well. Easy enough job, just be careful with the PCV heater cables
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- 3gGT01
Barty, sent you a DM.
- MikeyH
Washed then polished exterior, wife gave the interior a spruce up. Looks like new Then went out for a drive to Totnes to show it off.
- chanlon1
Thanks for the warning but I’m not familiar with this part?
