Hi
So I think I have the dreaded engine mount bolt issue as described below - car is going into the Dealer tomorrow afternoon to be looked at under extended warranty.
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=22166
I have done some searching but could find any decent photos of the actual engine mounts on the engine and thus their bolts - can anyone help here?
How do you see them / get to them?
For those of you who have torqued existing bolts, replaced snapped bots or even replaced the complete mounts - is this a big labour job? I’m just trying to pre-determine my wait time and what this has cost people in time and parts for those of you out of warranty.
**UPDATE 07 06 2013**
Car went into dealer yesterday and I showed them the SIB http://www.shipkiller.com/SI%20B%2022%2001%2009%20-%20Engine%20and%20Gearbox%20Suspension%20-%20Engine%20Vibration%20-%20Feb%202009.pdf
10 mins later they confirmed that on the right side engine mount bracket - 2 bolts had worked free and were missing and as a result all the strain was placed on the remaining 2 bolts on that side. As a result and extended driving a 3rd bolt snapped which cause the engine to slip down (around the final bolt on the bracket) and thus the vibration/noise was being cause due to the engine sump touching the anti roll bar (ARB).
They didnt have the correct bolts in stock and also needed to drill the snapped bolt out so I am rebooked back in for 2 weeks for the full job to get done. They said they would need the car for 2 days in order to strip it down and see if anything else neded to be replaced and to then submit the claim to Mondial BMW warranty.
In the short term they used some bolts for the 2 empty slots and torqued them to the correct settings - no more vibration.
I cannot see why this would not be covered under warranty - but am armed and braced just in case.
Wanted to make others aware again (i know others have) - but this is a serious issue which can hit anyone at anytime and no check or service will catch this. Shocking BMW didnt do a recall on this!!
Will keep you posted with my claim
Jamie
Jamie
Jamie
Jamie
