DTC/ABS codes
Onlinebigwinn
DTC/ABS codes
Evening
Got a set of codes that won’t clear- 53 plate 2.5
5DA3 wheel speed sensor front right
5DF4 system voltage <9v
5E5C initialise run flat indicator
I’ve replaced both front ABS sensors to no avail
The fault still won’t clear and 4 yellows remain
Any pointers/thoughts?
Cheers
Stuart
Cheers
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- pvr
DTC/ABS codes
On mine I had to replace the opposite one diagonal, so the code told me right rear and I had to replace left front for it to go. No idea why though.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Onlinebigwinn
DTC/ABS codes
Ah good to know!
Thank you
Thank you
EWS Delete PM me
EWS Delete PM me
- enuff_zed
DTC/ABS codes
But not rear left if the Speedo is working
Onlinebigwinn
DTC/ABS codes
Narrows it down!
EWS Delete PM me
EWS Delete PM me
DTC/ABS codes
Did you clean the reluctor ring whilst replacing the sensors and check it wasn't cracked or broken. That would throw codes.
Onlinebigwinn
DTC/ABS codes
But the codes would clear and come back
These don’t…
EWS Delete PM me
EWS Delete PM me
- enuff_zed
DTC/ABS codes
And there are only reluctor rings on the rear. The fronts are cast into the hub.
Onlinebigwinn
DTC/ABS codes
All sensors replaced
Code still persists
Any pointers chaps?
Code still persists
Any pointers chaps?
EWS Delete PM me
EWS Delete PM me
- enuff_zed
DTC/ABS codes
Think you’re into diagnostic swaps of the yaw sensor and dsc sensors then?
Unless it is a wiring issue.
- enuff_zed
DTC/ABS codes
Random thought: recalibrate steering angle sensor.
Onlinebigwinn
DTC/ABS codes
Agreed I’ll try both
I’m going to link up ista/inpa first to see if the creator code reader I took wasn’t up to the job of clearing the codes
EWS Delete PM me
EWS Delete PM me
Onlinebigwinn
DTC/ABS codes
Update
I’d left the car with the owner with the intention of going back with ista/inpa
However a spirited drive has cleared all the codes- thinking the car has relearned the adaptations
So all good case closed
EWS Delete PM me
EWS Delete PM me
