Soft suspension
Online
Soft suspension
What would make the suspension softer, less sporty.
There are days i think, i'm going to be rid of this car.
My daily drive is country lanes and my old bones can't stand all the bumping and giggling around in my car, std. 23i.
I went from the std shocks to Bilstein 6 then to 4.
So do springs make a difference, still on std. springs at 100k miles.
Can you get say softer spring to smooth out the bumps?
Not into going around bends at 100mph.
Soft suspension
What sie wheels are you running and have you got non runflat tyres. In my experience the Bridgestone runflats are the worst possible tyres. Again from my experience Michelin pilot sports or Goodyear Eagle F1 asymmetric will give a far better.ride
My car always on 18" wheels but going down on size will help but I dont have any experience of this.
More radical is to change the dampers -had a R56 Cooper S changed the dampers for Koni FSD's with michelin tyres completely transformed the car. Koni's now called special active.
If want to try smaller wheel or tyre combination sure 2.3I owners will soon be along to give there experiences- just remember ride quality is a very subjective see if you can get wheel/trye combination on the car on roads you know before making a big spend.
Dec 2009 Z4 35i DCT Deep Sea Blue
2018 3 door Cooper S DCT
sold 2003 e46 330ci Convertible
Online
Soft suspension
18" Goodyear Asy 5 F1's. I did consider the Koni shocks.
I did prefer the earlier F1's, the later seem harder wearing.
- Marcoose
Soft suspension
More cushions, grandpa.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
Soft suspension
Budget depending quality coil overs do the job. I put KWV3’s on the 35i and it transformed the ride and handling, it can be marshmallow soft or stiff but still compliant as they have bump and rebound adjustments. Would be cheaper than changing the car.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Online
Soft suspension
If its an M-sport could you not just fit Se springs.
Find somone with 2.3i Se first to see what difference in ride is.
Soft suspension
Running standard m sport shocks with eibach pro kit springs (progressive spring rates) and Goodyear Eagle F1 asymmetric tyres here. Rides way better than stock with the run flat Bridgestons. No idea how they released a car with such a terrible ride from factory. I'm also running wheel spacers and I'm convinced they helped the ride even more.
- B21
Soft suspension
Given he finds B4s too harsh,it’s non MSport and it’s on 18” non run flats it’s time to move on..
- IMG_2597.jpeg (100.07 KiB) Viewed 283 times
A very modified Atacama Yellow 35is
Online
Soft suspension
I think i need a car where i can wear granddads flat cap, Dad's 70's three quarter length camel driving coat and Jackie Stewart's driving gloves.
A Jag......
Always wanted my friends 1998 xjr sport, lovely car.
A Jag......
