2006 Z4M Roadster minor refurb thread
Hi guys, I'm doing a light refurb on my Z4M.
Will post vid updates here.
https://youtu.be/2OKW29xzID0
Love videos. Thanks for sharing
Thoroughly enjoyed that and taken some inspiration on the chassis clean up
Also worth checking the vanos unit, especially the exhaust hub tabs as they're a know weak point in the s54. Happy to help in you need any advise.
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
Cool. Any simple way to test VANOS? I don't know much about it yet.
Exhaust is off now. Wow! What a heavy exhaust this car has. I think some sections need replacing.
You can test the functionality of the vanos seals using ISTA but that only tells you one part of the story. The more important check is of the exhaust hub driver tabs, which can only be done with the valve cover off. There's plenty of videos on YT, this one is a good guide:
https://youtu.be/26myJ_Q0v6g
If you are thinking of tackling the vanos unit, pm me as I have done many over the years and have all the original timing tools, a refurbished vanos unit on the shelf and BMW parts you'll need.
Minor refurb of rear end: https://youtu.be/0XH8FSdMvds
Differential Pinion Oil Seal Replaced: https://youtu.be/tVZw6FOiD-c
Great effort on the diff
Just a note on torque settings, the driveshaft bolts are 100nm on our cars as its the steel torx bolts not the silver torx bolts found on the very earliest E46 m3.
- Screenshot_20230306_004343_com.google.android.apps.docs.jpg (83.04 KiB) Viewed 874 times
The propshaft torx bolts are 70nm
I knew posting these vids would be useful! Thanks a lot.
OK so my prop bolts are 10NM too tight, I guess that's OK. I'll increase the driveshaft bolts to 100NM.
My driveshaft bolts are actually a dark green, I guess that's what BMW call black?
It's weird that we have to get our info from M3 diagrams, I wonder why there isn't Z4M info out there? I checked RealOEM for Z4M but nothing useful.
Fortunately for us, the rear axle is almost identical to the E46 m3 with two exceptions, first being the differential heat sink and secondly the radius arm which uses a different bracket to secure the rear brake flexible hose.
I'm currently trying to modify an E46 m3 radius arm to secure the rear flexible hose bracket: Will report back when I've figured it out.
Dark green is bmw black in this instancejontZ4M wrote: ↑Mon Mar 06, 2023 11:38 amI knew posting these vids would be useful! Thanks a lot.
OK, exhaust now modified and sorted: https://youtu.be/_8hwMZnLd58
