First inspection of Z4M throws up some issues, feedback appreciated
Can't see how it robs power at all. When the car is started the mixture is very rich to keep the engine runnimg. The pump adds air into the exhaust so that the overly rich mixture has enough oxygen to burn off in the exhaust while the cats, o2 sensors and engine warm up a bit. It runs for a few minutes then switches off. Yes it has some weight but put 5 litres less fuel in and you will save more than the pump weighs.
Hi guys thanks for the replies.
Follow-ups:
- car was bought from Goldstone Cars in hitchin. I did have a good look over the car before buying.
- sounds like white scum on oil lid is from car doing short journeys. I've ordered the correct 14mm socket and a HG sniffer, so will go ahead and do further tests just to make sure.
- regards exhaust leaks, will assess further when I have it off the car. Will investigate further into aftermarket systems.
- will probably update rust correction progress with videos as soon as I get my camcorder working again.
- Ok sounds like I can remove secondary air pump system without huge repurcussions. Begs the question; if this is the secondary air pump, where/what is the primary pump?
- regards the diff oil leak, as it doesn't seem to be time-critical, I may investigate changing the seals myself. It sounds like a DIY-doable challenge. Is there a BMW website where you can order any BMW OE parts? When I was into Nissans, we had a super useful website that allows you to order any OE part for any Nissan pretty much.
Follow-ups:
Does anyone know what type of steel the OE exhaust is please? Might be able to weld it up myself if it's not too corroded.
- grannyknot
Weight, electrical draw, turbulence all rob power, yes? Extra fuel is spent to run and carry the SAPS, yes? The phrase I used was "a bit of power".Sajk wrote: βMon Jan 09, 2023 5:45 pm Can't see how it robs power at all. When the car is started the mixture is very rich to keep the engine runnimg. The pump adds air into the exhaust so that the overly rich mixture has enough oxygen to burn off in the exhaust while the cats, o2 sensors and engine warm up a bit. It runs for a few minutes then switches off. Yes it has some weight but put 5 litres less fuel in and you will save more than the pump weighs.
The real argument here is the reason it's there in the first place, I'm arguing that it's there only because it appears to help but you can't burn more fuel and expect it to create less pollution, not unless you're a politician of course.
Apologizes to the OP, didn't mean to take your thread off track.
Let's start another thread if anyone wants to continue with this subject.
2008 E86 M coupe
Toronto, Ontario
Toronto, Ontario
- buzyg
It's stainless. Yet appears to rust a little. Doubt it would weld easily.
Yeah, think it's a Mild Stainless steel,as opposed to Full 304:grade Stainless,which is probably why they rust.
Probably only have added another Β£3-500 to the cost of the car if they'd made it in Full 394 grade,haha....but that would also mean BMW couldn't charge obscene money for replacement exhausts
Interlagos Blue M RDSTR,2008. Logic7 dsp Hifi;satnav,stubby,htd seats,etc,etc.
Black 2005 3.0i NOW SOLD(and missed)
- Mr Tidy
If it is any help you can find Part Numbers on here:- https://www.realoem.com/bmw/enUS/selectjontZ4M wrote: βMon Jan 09, 2023 5:52 pm - regards the diff oil leak, as it doesn't seem to be time-critical, I may investigate changing the seals myself. It sounds like a DIY-doable challenge. Is there a BMW website where you can order any BMW OE parts? When I was into Nissans, we had a super useful website that allows you to order any OE part for any Nissan pretty much.
Cotswold BMW and Sopers of Lincoln both offer a discount to forum members and will post parts.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
The primary pump is the engine itself. An ICE is a massive air pump
- Argenta
Well you never floor it while its in use (stone cold engine), do you. So no, it doesnt rob power.
- peteslag
Mine had a very low pressure leak until one day (after a spirited drive) it was bloody hoofing out. I looked into doing it myself but realised that there was quite a lot of work involved and ultimately I couldn't be bothered. I ended up paying an indy Β£350 to do it in the end. The exhaust needs to come off to do it so maybe you can combine those particular jobs.jontZ4M wrote: βMon Jan 09, 2023 5:52 pm - regards the diff oil leak, as it doesn't seem to be time-critical, I may investigate changing the seals myself. It sounds like a DIY-doable challenge. Is there a BMW website where you can order any BMW OE parts? When I was into Nissans, we had a super useful website that allows you to order any OE part for any Nissan pretty much.
The underside of my car isn't too bad but I'm still planning to treat it next week. I was going to use lanoguard, I'll let you know how it goes.
Great looking car by the way.
^^^ thanks again for the feedback guys. Much appreciated. If someone could now just please create some more hours in the week so I can get on with it
And some more daylight and warmer weather
Joking aside, all of what you've discovered on your Z4MR is normal/to be expected on a UK teenage car.
I'm in the process of restoring my Z4MR and currently working my way through the rear subframe, trailing arms, bushes etc and happy to help with OEM part numbers if your struggling or general advice having parted out a Z4M Roadster last year. Just drop me a pm
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
Certainly will do thanks.Wassup wrote: βThu Jan 19, 2023 2:46 am I'm in the process of restoring my Z4MR and currently working my way through the rear subframe, trailing arms, bushes etc and happy to help with OEM part numbers if your struggling or general advice having parted out a Z4M Roadster last year. Just drop me a pm
