Wind Deflector
- r2uzenblot
Wind Deflector
My second user car doesn't have a wind deflector fitted. Has anyone any experience of these on ebay? Only £29.99....... https://www.ebay.co.uk/itm/224523968800 ... SwQYBfN5RW
- s-l500.jpg (31.98 KiB) Viewed 1100 times
2023 G29 20i M Sport Portimao Blue
2021 Triumph Tiger GT Pro
2008 Triumph Sprint ST
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
- enuff_zed
Wind Deflector
I assume you have a G29, but this photo is on an E85.
I suspect it would not fit.
Wind Deflector
It’s also toilet as well. I can send you mine if you want. I think I haven’t thrown it away yet.
- Scubaregs
Wind Deflector
Add does say G29 although pics say different. If you look closely at the pics, it's just a bit of fabric that is held in place by sliding the pockets of both ends over the roll bars, so I suspect it would fit the G29 and look as equally shyate.
OnlineArgyll Andy
Wind Deflector
+1
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- r2uzenblot
Wind Deflector
You are all right of course. Why put a string vest in between the seats. A very silly idea.......
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
Wind Deflector
Did you ever get a wind deflector sorted out?
I have been having a look around and there's not too many options around for a retrofit Wind deflector that looks stylish.
My car was prebuilt and didn't come with a wind deflector and it is pretty blowy compared to my Nd MX5 not as bad as my A5 cabriolet but could be better.
Going to have to go down the DIY route..... looks straightforward, what could possibly go wrong!
2021 Z4 2.0 White with Pro Pack and I did download the £160 Auto Dip headlight option!
- r2uzenblot
Wind Deflector
Snap..... I had an ND and am in the same position as you that my car was pre registered and had no wind deflector. My MX-5 did 95% plus of it's miles with the top down and my Z4 will be the same. Unfortunately the only solution I have found is to have the factory kit retrofitted as the 'string vest' idea is not really thew right solution. I will bite the bullet and get the factory one fitted but it may be cheaper to buy the whole kit and get a local indie to fit it.
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
Wind Deflector
Retro fitting wind deflector is very easy and can be done in minutes. See my post here viewtopic.php?t=124730&start=15
Wind Deflector
Thanks for the link, Roadster_Surrey very interesting.
I think I am going to go down that route.
Will keep you posted.
Wind Deflector
Well I went into the shed and.........tested to 55 so far and still attached!
Cheap n rough a bit like myself!
- 20220202_125709.jpg (144.28 KiB) Viewed 561 times
