This was my father's mig welder that he used as a hobby welder and was passed to me on his death.
No idea how old it is.
I do know it works as a friend has recently tried it for me.
I can't electric weld, I use oxy acetylene.
There are spare tips and a spot welding tip, original weldingmask (not brilliant quality) & manual.
It has a gas bottle and regulator just not sure how much is in the bottle, the welding cable roll looks fairly full to me.
Obviously it is for collection only from Warrington Cheshire as it's far too heavy and cumbersome to send via courier.
Must be worth £100 to someone.
I think that it can even be used on an 'M'
Online description says:-
A popular 150amp hobby welder with unsurpassed performance. The professional style, non-live torch, wheels and handle make for an easy to use machine. You can use this machine to weld mild steel up-to 6mm thick and with the correct additional kit, Aluminium and Stainless Steel too. It will accept either mini or 5kg spools of welding wire. It comes complete with a 390g, CO2 gas bottle, welding torch, gas regulator, mild steel welding wire, earth clamp and face mask – everything you need to start welding.
Power settings from 30 - 150amps. Welds mild steel up to 6mm. Also accepts aluminium/stainless steel.Turbo fan cooling for improved duty cycle & transformer life.Uses 0.6 / 0.8mm wire up to 5Kg spool.Fully variable electronic wire speed control.Operates from 230v, single phase power supply (15 amps minimum).Thermal overload protection with auto reset.Fully inclusive welding package - CO2 gas, regulator, mild steel wire, professional torch assembly, earth clamp, face shield & helpful instructions
FOR SALE Clarke 150te MIG Welder
- Owdgit
I like to think I'm an optimist.
2010 Grey Z4 E89 N52 3.0 with stuff
2018 VW Arteon 2.0tsi daily workhorse
2020 KTM 1290 Superduke GT
- Owdgit
Some pictures, hopefully
- 20200816_100603_resized.jpg (164.5 KiB) Viewed 525 times
- 20200816_100658_resized.jpg (142.84 KiB) Viewed 525 times
- 20200816_100635_resized.jpg (193.36 KiB) Viewed 525 times
- 20200816_100721_resized.jpg (167.23 KiB) Viewed 525 times
Pretty sure this model was made in Italy so it's a decent bit of kit and a steal at £100
