Rear Fog Lights E85 2.0 2006 Facelift
Umfaan
Post by Umfaan » Sun Dec 30, 2018 4:50 pm
I have noticed the only the drivers side lights up ....although there is a light Bulb in both sides ....checked both bulbs and all working. Is this a Left had / Right done thing done at factory. Can a fellow member look on there car and see if its the same. Otherwise i have an issue , wiring or something else.
Gjm91
Post by Gjm91 » Sun Dec 30, 2018 5:00 pm
My face lift e85 only has one operating fog light - think other side has working bulb as when you have an emergency braking situation fog lights act as extra brake lights
E89 2.0 i S Drive M Sport
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
Umfaan
Post by Umfaan » Sun Dec 30, 2018 5:32 pm
Interesting ...... :D
biojo
Post by biojo » Sun Dec 30, 2018 7:36 pm
only drivers side will work, but you can program the other side to come on, but its one or the other.
Scooba_Steve
Post by Scooba_Steve » Fri Jan 04, 2019 11:31 pm
Because the fog lamps are used for the Brake Force Display, only one comes on as your rear fog light. If you code the car LHD it will swap, you have no issue :)
Umfaan
Post by Umfaan » Fri Jan 04, 2019 11:53 pm
Thanks .......as clear as fog... :D
AngryZed
Post by AngryZed » Tue Feb 05, 2019 6:05 pm
Scooba_Steve wrote: Fri Jan 04, 2019 11:31 pm Because the fog lamps are used for the Brake Force Display, only one comes on as your rear fog light. If you code the car LHD it will swap, you have no issue :)
I had to add/retro-fit rear fog lights to my car (E85) out of EU regulations, I coded both sides because I did not like the single side look. Wonder if my brake force display work now, will have to test it I guess.......
2005 E85 3.0i 6sp Manual Black USA spec.
2008 Cbr 600-RR - Track use - back home
1994 Cbr 600 F2 - Sold
Scooba_Steve
Post by Scooba_Steve » Sat Feb 09, 2019 5:12 pm
It should still work but obviously if you have fog lights on then it wouldn't be noticed. You can code the centre (I have done this) and possibly sides to flash.
Sgub
Post by Sgub » Sun Feb 10, 2019 1:10 am
biojo wrote: Sun Dec 30, 2018 7:36 pm only drivers side will work, but you can program the other side to come on, but its one or the other.
Just wanted to say, very good to know! :D
There's a slim chance I might be moving abroad and taking the car with. So being able to leave original rear lights in and just recoding the other fog light to operate could make life (car-wise) a lot easier.
biojo
Post by biojo » Sun Feb 10, 2019 12:52 pm
just remember the front lights wont be correct if yer driving on other side of road
Sgub
Post by Sgub » Sun Feb 10, 2019 6:14 pm
biojo wrote: Sun Feb 10, 2019 12:52 pm just remember the front lights wont be correct if yer driving on other side of road
Did know that one, thanks!
