Average speed cameras
- maxman
These have been installed on the A5104 Llandegla to the A5 at Corwen.These are the first in N Wales as far as I am aware,a sign of things to come.
- buzyg
Over what distance? What is the speed limit?
We have several in Cornwall. But hey are all located in villages at 30mph limit. I have no problem with that at all.
Pass and get your plate snapped, pull over for 30 mins, then spank it
- bluespit
when did that happen? I was up there on Friday. didn't see any cameras? ooooppppsssss
now I'm about to have more time I've suddenly got less toys to play with!
Scooba_Steve wrote: ↑Sun Apr 08, 2018 10:50 pm Pass and get your plate snapped, pull over for 30 mins, then spank it
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- maxman
- maxman
- pvr
I have never seen an average speed camera in 30 limits though, always at 40 - 50 only. Drives me mad.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- adam04
I'd be intrigued what the tolerances are on the average ones compared to normal. I've never quite understood how being so focused on your speedo rather than the road makes things safer?
2003 E85 3.0i Auto Titanium Silver / Aerobody Kit / Cruise / Xenons / Cupholders....
- jimmybell
tolerances now CAN be down to... zero. as in, no tolerance.
it's up to the local authority who they fine and what tolerance they allow. avg cameras are fine, they just need to be clearly signed, and sensical. they don't typically deploy them without reason (ie, past incidents)
i know a guy who got speed awareness course for 61 in a 60, and my mrs managed 3 points + £100 in a 70 doing 92, if they swapped counties she'd be in jail and he'd not of received anything in the post.
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
- pvr
Jailbird springs to mind? Ok, will get my coat ..
Speed limits and the punishments are a strange thing, I drive more in Europe nowadays than in the UK, but it is strange that nothing changes on the road and suddenly the speed limit goes up because you entered a different country. Even weirder when you cross into Germany that you suddenly go from the risk of a huge fine to nothing, just because you crossed an invisible line somewhere.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Why is this 'excuse' trotted out so many times? Why do you have to be focussed on your speedo. It's hardly difficult to glance at the speedo every 10 seconds in an average speed zone, and they're usually not on roads that you have to keep your eye open for lots of hazards. It's like saying you can't look in your mirrors as you're too busy looking out the windscreen.
I can't believe people who get caught claiming they didn't know the speed limit either. If you want to take the chance (like I do, often) of driving above what you consider an artificially low limit, then take your punishment when you get caught. In all but one case when I've been caught, I can say that I have known what the limit was that I was breaking, and that one case was where a 70mph limit had recently been changed to 60mph, but only in one direction - the other direction was 40mph, and at 2am in the morning I wasn't really looking at the speed on the new repeaters (but that was over 20 years ago).
- bluespit
What poles? Might nip up there this afternoon to check it out!
- maxman
Do you need some part-worns and a gallon of petrol
