Behaviour
Behaviour
I wear hats as my thermal thatch has dissolved and it's blooming cold without one. We have just moved into our new project house, so will be more busy on it.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Behaviour
I've been a member since 2011 - enjoyed all the banter especially on political issues - entertained by some of the " rants " - really good to see the support given on occasions when someone is going through a hard time
I don't wear a hat but if I did it would have an M badge
Agree with the zero tolerance policy
- Marlon
Behaviour
Great motto - sums things up perfectly, maybe we should have it as our banner
On a personal note; there's a fine line between banter and ridicule and I believe I've been guilty of crossing that line once or twice too. It was suggested I'd crossed that line quite recently on a Z4 sales ad and upon reflection perhaps I had. The Mods should be setting the standard and I have taken it as a positive criticism, and will be mindful moving forwards.
Gone: 3.0si 2008 E85
911 997 Carrera S
- Ducklakeview
Behaviour
Thanks for saying that when i read people going off subject and verbally attack each other i cant be bothered and log off
But generally this is a good forum with encouraging people and good advice
Big Mike signing-off
E85 sterling grey 2.5 2003 17inch alloys
Roof pump relocated in boot
- paddy wright
Behaviour
- tonyz4c
Behaviour
I must admit, I haven’t seen anything myself here
but i have seen the case elsewhere
As it tends to be always the same persons i finnaly used a nice feaure
in control panel / friends & foes
you add his login in foes list and all his posts are hidden
That keeps you calm and moderate , plus you don't put yourself in
thanks to the moderators team
Z4MC Carbonschwarz - Caramel
Database of M /3SI http://perso.numericable.fr/tonyz4c
- brightonbimmer
Behaviour
Something I just read the other day on the internet, by way of advice: When you have prepared a response which sums up your feelings but is not necessarily complimentary, and possibly rude, first you should read it again, twice, and then, before clicking "send", click "delete".
David
David
