Offset confusion
Offset confusion
I've found some wheels I like but I'm confusing myself with the offsets now, could someone let me know if the following would fit please?
FRONT WHEELS: 225/35/19
8.5J X 19
38 (OFFSET)
REAR WHEELS: 255/30/19
9.5J X 19
40 (OFFSET)
If I'm reading correctly would I just need a 10mm spacer on the front?
8.5J X 19
38 (OFFSET)
9.5J X 19
40 (OFFSET)
- mr wilks
Offset confusion
What model Z4 ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- mr wilks
Offset confusion
Wheels will fit fine without spacers but tyre sizes are under what they could be .
On 8.5j 235 35 would be better & the rear 9.5 ideally 265 30 or 255 35
Very little rim protection on the current numbers & could feel harsh on the road
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Offset confusion
Standard size e89 rubber for 19s arent they Mr W?
Totally agree tho they look like rubber bands and will probably end up cracking the wheels and your fillings
18 Z4s owned to date.
Current: 2.5i Titan silver
- mr wilks
Offset confusion
Well yes standard as in from factory but that would be with the factory 8j & 9j wheels as opposed to 8.5j & 9.5j OP has mentioned .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Offset confusion
Thanks for your help, appreciated
Offset confusion
Hi, could I ask your expert opinions again please? Some other wheels have come up very close to me but from reading above I think the tyres may be too large.
265/35/19 et38 9.5j
235/30/19 et33 8.5j
265/35/19 et38 9.5j
235/30/19 et33 8.5j
- mr wilks
Offset confusion
Perfect widths but profiles (if correct) are opposite to what they should be ?
The 35 should be fronts & 30 rears
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Offset confusion
Thanks again Mr Wilks.
These are the tyres on currently, I guess they'll fit then but the ride won't be great? I'd look at replacing asap
- mr wilks
Offset confusion
Well the ride on rear 265 35 will be good & providing you aren't lowered then they shouldn't rub . It's the fronts that need upping to 235 35
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Offset confusion
I'm in luck, picked them up today and turns out the fronts are 235/35/19
I'm planning on fitting tomorrow so I will try and get some photos up
- mr wilks
Offset confusion
Result , get some pics up
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Offset confusion
I've got them on, now I'm thinking I may have to lower soon
- 20180114_135306.jpg (312.92 KiB) Viewed 1012 times
- 20180114_135327.jpg (321.9 KiB) Viewed 1012 times
