Tyre Pressures
Alloy wheels and tyre discussion
scooobydont
Tyre Pressures
Post by scooobydont » Sun Nov 12, 2017 7:33 pm
I am running 255 35 18 rears and 225 40 18 fronts, tyres are Hankook. Car is an E85 3.0i. Can any recommend what tyre pressure I should have? I have had a google and answers seem to vary quite a lot. I am currently running 36 in the rear and 34 in the front.
Mark-Z4
Tyre Pressures
Post by Mark-Z4 » Sun Nov 12, 2017 7:44 pm
I'm not too far away from that on 19's, I run 33 front and 37 rear. I just had a play around and settled on these.
E86 - Space Grey | Grey Oregon Pearl Leather | Sport Interior | ///M Bumper | Aero Skirts | Piano Black Trim | ///M Wheel | Eibach Pro | CSL | HID | LED | ZHP | MM Tips | Stubby SOLD
Marlon
Tyre Pressures
Post by Marlon » Sun Nov 12, 2017 7:52 pm
I keep it simple and stick to 34 all round
Gone: 3.0si 2008 E85
911 997 Carrera S
jabber
Tyre Pressures
Post by jabber » Sun Nov 12, 2017 10:02 pm
Had mine 32 front 34 rear
Z less again
scooobydont
Tyre Pressures
Post by scooobydont » Sun Nov 12, 2017 11:02 pm
Thanks for the reply chaps. Sounds like I wasn't too far off, it feels a little too 'solid' hence the query.
Online
patriot66
Tyre Pressures
Post by patriot66 » Mon Nov 13, 2017 1:49 am
The recommended tyre pressures should be on a sticker in the drivers door shut. Also on page 73 in the Owners Handbook. :thumbsup:
scooobydont
Tyre Pressures
Post by scooobydont » Mon Nov 13, 2017 8:32 am
Never thought to look there! :thumbsup:
MACK
Tyre Pressures
Post by MACK » Mon Nov 13, 2017 8:49 pm
scooobydont wrote: Sun Nov 12, 2017 7:33 pm I am running 255 35 18 rears and 225 40 18 fronts, tyres are Hankook. Car is an E85 3.0i. Can any recommend what tyre pressure I should have? I have had a google and answers seem to vary quite a lot. I am currently running 36 in the rear and 34 in the front.
The key question here is are you running runflats or not. If you are I would stick to what the handbook says. If not pressures closer to the M models are more appropriate F30 R32. As a lower front tyre pressure is used to induce a bit more understeer I went with 32 all round on non runflat M size tyres (same width as yours but 40 instead of 35 on the rear and 45 instead of 40 on the front).
Silver 05 3.0i SE
Mods inc - F/L Xenons Clear Ind Rear Lights M Sport Seats & Wheel Eibach/B4 3.64 DIFF (SOLD)
White E89 20i M Sport
Mods inc- B12 kit, M3 Arms, 18" Zito 935's with PS4's, Decat & Remap, Switchable Exhaust Flap (SOLD)
scooobydont
Tyre Pressures
Post by scooobydont » Mon Nov 13, 2017 10:59 pm
MACK wrote: Mon Nov 13, 2017 8:49 pm
They are not run flats. I may drop the pressures a little at the weekend and have a play.
Jamesw
Tyre Pressures
Post by Jamesw » Wed Nov 15, 2017 12:00 pm
I have the 3.0 coupe with non run flats. I’ve just fitted 17 inch winter tyres and am running 31 front 33 rear. Not sure if that’s correct but seems ok to me so far
Z4 Coupe, 58 plate, black, love it :driving:
