2007 BMW Z4 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7LL
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
Parking light
2825LL
Front turn signal
H21W (64136)
Rear turn signal
7507AST
Tail light
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
H21W (64136)
7528
High mount stop light
Assembly
Fog/Driving light
H11LL
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921LL
H8-35W
Cornering
H8-35W
Front sidemarker
2827
Map light
2886X
Dome light
2825
Step/Courtesy light
2825
Trunk/Cargo area
6411
This is to be used as a guideline only. Not responsible for anything that goes wrong or if there is an error, omission, crap like that. Use at your own risk.
Courtesy of OSRAM SYLVANIA
2007 BMW Z4 bulb listing
Re: 2007 BMW Z4 bulb listing
To make things simpler a lot of the Osram bulb type numbers are more complex numbers when in actuality they are more commonly called 194/168 peanut/wedge bulbs. If you Google the numbers and cross reference them.
Parking Light "sidemarker in headlight" : 194/168 (wedge/peanut)
Front Sidemarker "side sidemarker w/ emblem": 194/168 (wedge/peanut)
Map Light: 194/168 (wedge/peanut)
Dome Light: 194/168 (wedge/peanut)
Step/Courtesy/Footwell Light: 194/168 (wedge/peanut)
Trunk/Cargo: 194/168 (wedge/peanut)
Front Blinkers : BA9S 12v 21W
Angel Eye Bulb: BA9S 12v 10W
Is this for UK spec cars? I have a US spec car and don't have H7 high beams, is that something that can be retrofitted? The HIDs are bright, but don't broadcast that far down the road20ducks wrote:2007 BMW Z4 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7LL
The 06+ Bi-Xenon have the low beam, high beam, and flash2pass all using the HID low beam and projector. The inner projector is a mock projector that houses the angel eye bulb.
Do the flash2pass use the bi-xenon high beam? I was parked in front of a glass store window without any lights on and hit the flash2pass lever and the outer lights came on very fast and very bright. I didn't think hids came on that quick and I also read it was not good to turn them on and off allot. It there any way to add a halogen bulb to the inner projector for high beam use?BimmerZealot wrote:The 06+ Bi-Xenon have the low beam, high beam, and flash2pass all using the HID low beam and projector. The inner projector is a mock projector that houses the angel eye bulb.
- mcbeee
Are these the same for the 2006 M roadster ??? I don't have a manual so don"t say it
Sold the Z4 M Roadster and a 911 Carrera S now I have a 2021 Z4 3.0i
