Hi All,
I just bought a BMW Z4 E85 a few weeks back and although there were minor things that needed looking at I was happy that I could fix all of these myself or with a simple garage visit for things like alignment and new tyres.
I had only driven it 5 times before I thought I'd like a bluetooth module in the car so I went ahead and installed this adaptorhttps://www.amazon.co.uk/dp/B09V6ZGDMW?. The previous owner told me he had fitted a CD Changer and I could see that the surround was a bit mashed up from someone trying to take the air vent out previously. I fitted the module and it worked fine and even went for a drive and enjoyed my music finally.
The next time I drove the car I brought home an Autel scanner to see if there were any faults with the car. I was surprised that there were quite a few faults which looked to be either absent sensors, shorts to ground or voltage supplies. Two most notably were with the ESP which were:
006128 - Electric Power Steering (EPS), vehicle speed - Status Absent
006116 - Electric Power Steering (EPS), relays - Status Absent
I thought well there isn't anything on the dash so I'll drive to where I needed to go that day and deal with them later. Upon getting on the motorway and yellow engine warning light came on so I pulled over, did another scan and couldn't see any faults which were new. My thought process now was to wipe the fault codes so if the light were to come on again I'd have the most recent codes so I could pinpoint the problem.
The light didn't come back on and I got to my destination.
After a two hour walk I got back to my car and now the power steering light is on and the wheels are hard to turn. Did another scan and now the ESP will not respond to the diagnostic tool.
I've since been looking at the forum for posts on things to try in order to get it responding again and I've done the following:
Unplug battery and leave for 1 hour.
Unplug the changes to the radio just in case it was causing some sort of CAN interference.
Test the fuses
Visually inspect the cables going into the ESP and plug and unplug them
Test the power cables are fine with a multimeter.
Put a booster on the battery to provide the car with slightly more power in case the ESP wasn't getting enough. (The Autel scanner says its voltages are within a good range)
My hope is that I can figure out what the problem is rather than having to send the ESP module off to get rebuilt at ECUtuning.
Test the fuses
