Power folding mirrors have stopped working
Afternoon,
I'm hoping someone can help with diagnosing the mirror problem.
Z4M with powerfolding mirrors which suddenly stopped folding. All the other functions still work for both sides. Checked and replaced the fuse (27) with no luck.
Hopefully you can resolve this problem (apologies i have no advice!).
In case you need to replace them (hopefully not needed!), i have a pair of power folding mirrors (+ the module which is needed for install) for sale.
I'll keep that in mind. Would be surprised if they're the mirrors themselves as both have stopped simultaneously.Scaramanga wrote:Hopefully you can resolve this problem (apologies i have no advice!).
I'm more inclined towards the actual switch (although the glass adjustments are working for both sides) or a wire somewhere.
Makes sense. Fingers crossed easy fix!
Could be the switch, it's separate to the mirror control. It may be worth trying an electrical spray cleaner on it. I had this on an old 5 series that my mum had, a couple of the windows didn't work from the main switch, so plied the buttons with WD40 and after a few button movements they came back to lifeBabw wrote:I'll keep that in mind. Would be surprised if they're the mirrors themselves as both have stopped simultaneously.Scaramanga wrote:Hopefully you can resolve this problem (apologies i have no advice!).
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- mac27040
I would get someone to run a diagnostic check to communicate with the mirror fold module to see if it's ok. Otherwise check switch and wiring if fuse hasn't blown. Might be for some reason need coding again to activate it.
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Would it be INPA I'd use to check the module? I'm sure I've got that on a laptop somewhere.mac27040 wrote:I would get someone to run a diagnostic check to communicate with the mirror fold module to see if it's ok. Otherwise check switch and wiring if fuse hasn't blown. Might be for some reason need coding again to activate it.
- mac27040
Iona might show any errors, I use DIS v57 for diagnostics which also give options. You might ncsexpert to check if option needs re-activating
- Yeddheng
If condensation forms on the cold drink you have in the cup holder, then it can drip down on the buttons.firebobby wrote: Could be the switch, it's separate to the mirror control. It may be worth trying an electrical spray cleaner on it. I had this on an old 5 series that my mum had, a couple of the windows didn't work from the main switch, so plied the buttons with WD40 and after a few button movements they came back to life
I have thought that this could cause damage... here we might have the answer?
Try some electrical cleaner.
Z4 MC 07 / A08 Silver grey / Black interior w Carbon leather / VT+RE mounts / 10.9 / cdv- / RPi / Cup2 / Arc-8 / Lugs / KW V3 / GC camber plates / Vorshlag RTAB limiters / Custom alignment / Aux / Stubby / Mud flaps /
My Z4MC
My Z4MC
Don't have a cup holder but I'd be surprised if it's not a wire/switch issue.Yeddheng wrote:If condensation forms on the cold drink you have in the cup holder, then it can drip down on the buttons.firebobby wrote: Could be the switch, it's separate to the mirror control. It may be worth trying an electrical spray cleaner on it. I had this on an old 5 series that my mum had, a couple of the windows didn't work from the main switch, so plied the buttons with WD40 and after a few button movements they came back to life
To look at the switch is it just a case of slipping a card under the switch module and lifting it?
I would get some electrical cleaner and spray it into the switch as it may be gummed up, you can do this without removing the switch.Babw wrote:Don't have a cup holder but I'd be surprised if it's not a wire/switch issue.Yeddheng wrote:If condensation forms on the cold drink you have in the cup holder, then it can drip down on the buttons.firebobby wrote: Could be the switch, it's separate to the mirror control. It may be worth trying an electrical spray cleaner on it. I had this on an old 5 series that my mum had, a couple of the windows didn't work from the main switch, so plied the buttons with WD40 and after a few button movements they came back to life
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Tried spraying contact cleaner and operating the switch multiple times with no luck.
I think the next step is to check the wiring to the switch itself. What's the best way to take the switch out?
Hi. I fixed the same problem with my 2005 Z4. There is a short in the circuit board of the switch at the pin for that function. The pin is #2 on the right top when looking at the board's solder side (with the large set of pins facing up- same position as in the arm rest).
Use a small soldering iron to heat up that pin socket and move the pin down and back to get a good connection with the pin's trace.
Confirm with an ohm meter. It is a simple, easy, clean task.
Richard from Canada.
