M market watch
"M" Specific discussion
tomscott
M market watch
Post by tomscott » Sat Jun 23, 2018 11:59 am
Bodyboarder wrote: Fri Jun 22, 2018 12:21 pm Where can I find the ‘ tomscott’ write up ?
Thank you :roll:
Thanks Mr Wilks :thumbsup:
Have a quick look through my post history made a few what to look for posts. Here is a recent one talking about thrashed cars and how to spot signs but also go into detail on the positives of the S54 and what can happen and whats worth bearing in mind. Obviously all depends on the milage and time you expect to keep whether these things apply to you.
tomscott wrote: Fri May 11, 2018 10:37 am Its a sportscar and designed as such.
Look at any modern sports car for sale with pedegree they all have weaknesses its about doing your research and knowing what the weaknesses are and what to do.
Its fairly safe to say that all Ms will have been driven hard at some point, whats the point in having a sportscar without driving it hard every once and a while. That being said it is designed as such and the fact this engine is 20 years old and there are very few failures on engines from 2002 onwards. The Z4 especially as it was the last car this engine was implemented in, completely missed all the issues of the early engines. In the 7 years ive been a member I can think of 3-4 cars in total that have had engine failure. Many of those were either well used track cars or cars that hadn't been cared for properly or very unlucky people.
There are S54s with well over 150k on the clock, the fact this engine was at one point the highest output for a NA engine and the red line being so high its incredibly impressive.
At the end of the day the earliest Z4M is now 12 years old and there are a few of obvious things that you should look for. More detail can be found throughout the site with the search function.
1. Run in service - just make sure its done on time or within 10-20% IMO its not worth the risk.
2. Ensure the cars service history is correct. Oil every 2 years, make sure the cars had its inspections on time, inspections are milage based not time, but its not uncommon to see inspections early as a lot of cars are garage queens and dont hit the milage. Make sure the correct work is carried out. Many third party garages tick INS I and II when they do oil services but not carry out the correct work, look for specialists and contact them to see what level of service they offer etc ensure of valve adjustment. Generally if the service schedule has been done on time and properly the car will be mechanically sound. You can google to see what the inspections involve.
3. These engines are very tapperty, dont worry they are loud it doesn't mean its imminently going to blow up, many people new to the S54 get very concerned about the noise... If its knocking thats a different thing all together but sounds very different. Knocking is very rare on these engines and usually means its overheated at some point which again is extremely rare. Only case I can remember is some work was done and the system not put together correctly and a delivery driver didnt watch the temps.
4. Check paperwork, see what has been done. If the paperwork is well documented that would give you a good indication that its been well looked after. Go through all MOTs, advisories give an idea on how the car has been looked after. For example if at every MOT the tyres are down to the markers it doesn't fill you with confidence for other expenditure. These cars were super cheap in 2011-12 coupes with under 40k could be had for 17-18k and roadsters even less at BMW dealers. Made them available to a lot of people.
If paperwork is thin then its not the end of the world but it gives wiggle room. Only you can decide.
5. Buying a low milage car isnt always the best idea. Cars are designed to move and if they sit seals dry up, rubber components deteriorate etc etc Its not a given but generally lower milage cars will probably have done quite a few short journeys and thats not great for engines like this that take 10-15 mins to get to temp. There are obvious signs to check for this, bolster wear, steering wheel and gear stick shininess all show short journeys on low mileage cars. Still this wouldnt put me off again the engines are very durable.
6. Think about the time you will own the car. Consumables are good value imo for the performance offered but add up considerably and generally things need doing all at the same time. Make sure the car has had recent disks and pads all round, its roughly £7-800 an axle they last roughly 30-40k depends on the driver. Make sure INS have been done as that could be £5-800, tyres £5-900 depending on your preference etc etc an averaged price car that needs all this doing quickly turns into the value of a better example.
Essentially if all the above is done, you are consumable free for the next 2 years and the car will be very good value to run. Just ensure you know the costs going forward. Many owners tend to keep these a year 18 months to dodge costs, loads of examples are like this at premium prices just because there is hype surrounding these cars, can quickly end up costing more than you expected. Again if you know what your looking for its all wiggle room.
With the above, all within your own margin of expectation (everyone is different) buy on condition, mileage isnt really a big deal. Just make sure the cabin is in good condition and expect wear, they are low and somewhat difficult to get in and out of. Check bodywork for panel alignment, over spray, check in the boot under the trim for signs of accident damage, same with the engine bay. Dont be surprised if front bumper and skirts have chips/damage, Z4s are low and susceptible to stone chip and rash, on the same token dont be surprised if there has been paint work to remedy this.
There are additions which may or not apply but worth knowing about depending on what your buying.
7. There are out of service schedule items which are still serviceable, just not in the 3-5 year time frame BMW expected to offer these for sale. The weak point of these cars is the half shell bearings (rod bearings), as the engine doesn't have a dry sump it is susceptible to oil starvation in this area if the car is not allowed to warm up and oil circulated properly. Tolerance are low and they wear as a matter of course you cant get away from it. That being said the bearings are designed to last the BMW warrantied serviceable life of the car which BMW would say is 100k. Many have replaced them at 80k and they have been fine, others have seen wear at 60k and others have had them removed over 120k and they are still in decent condition. There have been cases of extremely warn bearings on cars with 40k. Whats worth knowing is that if your looking at a higher mileage car its probably worth having some money put aside to get this done anywhere between 80-120k. I would say 100k is a decent mark to aim for. Once its done its a worry you can put to bed. If you want to know get the oil changed in the car and let it run for 6-12 months and get the oil sent away for analysis and the particulates will give you an indication. Again there are threads upon threads about this, dont go and read up and get worried just know its a consideration.
8. There are other serviceable items that again are not in the schedule for the same reason as above. The engine mounts are rubber and I think passenger side mount is right next to a heat shield and tends to go quicker than the other. Regardless, the youngest car is 10 years old now and these will most likely be perished or well on their way. There was also issues with engine bolts which can come loose and snap under strain, might as well get these replaced at the same time. For no.7 and the bolts and mounts all done together your looking at around £1200 small amount in my mind to have piece of mind. Any good specialist can do this.
9. Vanos, much improved on these engines but the older they get the more cases will come along. Again these can be rebuilt at not huge cost by specialists but they are again reliable and there arent a huge amount of cases.
10. Have a little fund set aside. There are other problems that can arrise which would make this post even more of an essay, these happen on all cars with age. Culprits will be suspension, springs are well known for breaking, joints will have play with age. Will be fairly obvious from MOTs etc and a quick drive will let you know whether the handling is woolly or not. Break lines will corrode, xenon bulbs can go etc etc The positives is that there isnt anything really you can point at and say... This will break and there is nothing you can do about it.
At the end of the day the list is extremely short for a car of this performance and caliber. My advice is to know all of the above but if the majority is in good order buy with confidence. In terms of service history it will almost be impossible to get a car thats only BMW serviced. Make sure the oil is done, the inspections are important but you can always have an inspection done on purchase to ensure all is in order.
If in doubt pay £150 and have the car inspected then you will know exactly what your looking at. Its money well spent.
Just know there are a lot of poor examples, current prices (unlike the Porsche market) dont make this obvious as they are relitevely new to the lime light, they sold so poorly and are rare because they were slated at launch and the Boxster was arguably a better car. There are dogs for high money just because of rarity and association with these cars being a popular choice currently.
At the end of the day the prices have risen, they are safe investments if bought well and looked after. You could put 20K on and sell for similar money down the line. I bought mine in 2011 and sold it in 2015 for about £1000 loss after I put 25k on it. 2015 was just before the market rise and now a similar car would cost roughly 22-23k.
That is the coupe market tho the roadster market seems to be fairly level with prices topping at around 22k for super low milage cars and for leggy ones 10-12k.
Worth bearing in mind that the 3.0SI is about 95% on the road will cost half the amount and is more bullet proof and costs far less to look after, insure, tax but the M is certainly a gem in modern motoring and should be on every single petrol heads list in either form.
Hope this helps :thumbsup:
Bodyboarder
M market watch
Post by Bodyboarder » Sat Jun 23, 2018 12:44 pm
Thank you for the above :thumbsup:
Still looking as the one I just looked at was well under the condition that I’m happy with .
Anyone thinking of selling please get in touch .... if it has loads of scratches/dents/not been properly cleaned in 7 years please don’t get in touch :thumbsup:
Simon 3.2M
M market watch
Post by Simon 3.2M » Sat Jun 23, 2018 11:02 pm
Bodyboarder wrote: Sat Jun 23, 2018 12:44 pm Thank you for the above :thumbsup:
Which one did you look at?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Bodyboarder
M market watch
Post by Bodyboarder » Sun Jun 24, 2018 6:58 am
Pm’d
Not going to slag the car off on a public forum and the chap was genuine but it’s a case of people looking at the market and assuming that theirs is worth x amount just because it’s a z4mc ...... put it this way , I didn’t even make an offer and I’d driven a 5 hour round trip .
MrPT
M market watch
Post by MrPT » Thu Jun 28, 2018 5:43 pm
Evo’s used car deals this week: http://www.evo.co.uk/buying-advice/1967 ... f-the-week
It may not be a full-blooded BMW M-car but the two-seater coupe still has plenty going for it. Its sleek form conceals the 3.2-litre in-line-six engine, borrowed from the E46 M3, that serves up 338bhp and 269lb ft of torque, which translates to a 0-62mph time of 5.0sec and a 155mph top speed.
> BMW Z4 M review
It’s how the performance is delivered, though, that lends the coupe its raison d'être. The deep-chested, straight-six boasts a hearty mid-range, but it’s the effervescent top end where the Z4 M produces real fireworks. The engine is so good we can overlook the unresolved chassis that lacks the polish you expect from an ‘ultimate driving machine’.
This example combines a sepang bronze metallic exterior with a stone leather interior. In 12 years it’s covered just 60,000 miles.
See the ad at Octane here...
2006 Z4 2.5si: gone
Muckinonthesofa
M market watch
Post by Muckinonthesofa » Thu Jun 28, 2018 6:03 pm
MrPT wrote: Thu Jun 28, 2018 5:43 pm Evo’s used car deals this week: http://www.evo.co.uk/buying-advice/1967 ... f-the-week
> BMW Z4 M review
"It may not be a full blooded BMW M car".....????
Z4MC, Silver/Grey, Imola Red Leather, Sat Nav, Heated Seats, DSP, Intravee, Stubby, ZHP, Gruppe M, CDV, Bilstein B12's, Vibra-Technics engine mounts.
Status
M market watch
Post by Status » Thu Jun 28, 2018 6:20 pm
Pick my new m up tommorrow
MrPT
M market watch
Post by MrPT » Thu Jun 28, 2018 8:11 pm
Muckinonthesofa wrote: Thu Jun 28, 2018 6:03 pm "It may not be a full blooded BMW M car".....????
Doesn’t have “auto-blip” and crazy frog noises pumped through the stereo.
2006 Z4 2.5si: gone
AndyBeech
M market watch
Post by AndyBeech » Thu Jun 28, 2018 9:10 pm
MrPT wrote: Thu Jun 28, 2018 8:11 pm
Uses some parts and an engine from previous cars / M3 I guess is what they mean rather than bespoke
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
Looney
M market watch
Post by Looney » Thu Jun 28, 2018 10:17 pm
Status wrote: Thu Jun 28, 2018 6:20 pm Pick my new m up tommorrow
Let me come have a look once you get it :)
Mini R56 FJCW
Z4MC Imola Red
Status
M market watch
Post by Status » Fri Jun 29, 2018 5:54 am
Yeah ping me over yer number and I’ll give you a bell,I’m getting it today then it’s just gonner sit in me garage as got music stuff to learn for a couple of gigs coming up,off to Le Mans Classic next week in the Datsun so gradually getting that ready ,also have to do my bit at home to keep Dorris happy that way I get to go out to play more she doesn’t know yet that we are getting another border terrier after losing our other one last year,need another dog to go with our black lab,She also didn’t see me sneak in another Guitar I brought the other day,pain in the butt sometimes being popular ha ha
Simon 3.2M
M market watch
Post by Simon 3.2M » Fri Jun 29, 2018 7:32 am
Status wrote: Fri Jun 29, 2018 5:54 am Yeah ping me over yer number and I’ll give you a bell,I’m getting it today then it’s just gonner sit in me garage as got music stuff to learn for a couple of gigs coming up,off to Le Mans Classic next week in the Datsun so gradually getting that ready ,also have to do my bit at home to keep Dorris happy that way I get to go out to play more she doesn’t know yet that we are getting another border terrier after losing our other one last year,need another dog to go with our black lab,She also didn’t see me sneak in another Guitar I brought the other day,pain in the butt sometimes being popular ha ha
I've purchased a guitar - shame I haven't got a clue how to play it!!
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Status
M market watch
Post by Status » Fri Jun 29, 2018 7:47 am
I’m a bass player,just got a fretless bass to go with my collection
Darren Slone
M market watch
Post by Darren Slone » Fri Jun 29, 2018 3:05 pm
Get some pics on Paul :driving: :thumbsup:
Current Porsche Cayman S 987.1
Now sold - Imola Z4MC
Now sold - Silver Grey Z4MC
OEM CSL’s, Supersprint, Gruppe M, Eibachs, Carbon Roof, carbon rear spoiler,,
Now sold - My other Z
‘71 Datsun 240Z imported from West Coast USA
Looney
M market watch
Post by Looney » Fri Jun 29, 2018 4:24 pm
Mini R56 FJCW
Z4MC Imola Red
