M Track Mode enabled on Z4MR
Sorted it!!!
Not been for a drive yet but will later.
I'm in W.Sussex if anyone else wants this done!
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
I got this done a few weeks ago, well worth it, the car's been crying out for it for nearly 10 years. Douglas at B&M Centre in Glasgow did it for me, first time I've used his garage and am suitably impressed. I'm not sure of the exact price he'll charge as mine was done along with other work but I think he'll be looking for around the £100 mark to do it.
06 Z4MC, Sapphire black, Aero sideskirts, BMW strutbrace, CSL's, Remus back boxes, Intravee and Alpine DAB
- Bing
I want this done on mine now...
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
I'm very impressed, I last had this function on a 330c in 2002. I find it hard to believe it wasn't there as standard on the Z4M or E46 M3 when they included it on the CSL and CS. Get it done, you'll see a big difference.
- Argenta
Finally got on the bandwagon & got it activated, M-track is on!
Big big thanks to this thread!
Just waiting for a chance to try it out...
I've managed to activate.
I couldn't use expert mode as it threw up a version error.
So against better judgment to mess with what I don't know, I used 'Expertenmodus (often)' all went to plan but got an error after.
DTC lights up and holding turns traction control fully off, but the errors a little concerning.
Can anyone explain the error?
- Beedub
i have no idea but i didn't get that error on mine..... and if i did id have reversed it personally....
Would you mind helping me out with mine please mate?Beedub wrote:ill do this for anyone Sutton side...
currently teaching myself how to use the software to other codings , run tests too.
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
83’ VW B2 Passat CL
- Beedub
yes man no probs.... finally got a "new" Old laptop with windows 2000 works really well now....dannytheduck1985 wrote:Would you mind helping me out with mine please mate?Beedub wrote:ill do this for anyone Sutton side...
Thanx dude. I'll give you a shout when I'm ready.Beedub wrote:yes man no probs.... finally got a "new" Old laptop with windows 2000 works really well now....dannytheduck1985 wrote:Would you mind helping me out with mine please mate?Beedub wrote:ill do this for anyone Sutton side...
84’ E28 Alpina B9
83’ VW B2 Passat CL
83’ VW B2 Passat CL
- Argenta
Did my first trackday with M-Track yesterday.. Wow!
As said, why didn't they have this as std. Amazing help on track.
Ended up having it on all the time, instead of switching all off as usual.
Could relax a fair bit more and focus on everything else.
https://www.youtube.com/watch?v=cN0ZqNogDqI
Falkenberg Racetrack this.
Thanx again to this thread!
Bringing up an old post, but looking at getting the MTrack mode on the Z4MR this summer.
I want to get it correct, and what Beedub posted makes sense. Was this ever fully resolved, ie what needs changing to get full fat MTrack, and not just the 3.0 Si version? It doesn't seem as simple as simply changing
TRAKTIONDIFFERENZREGELUNG = aktiv
I know for example one setting is different between the Coupe which has the CSL rack, than the Roadster so
LENKWINKELKENNLINIE_2 = wert_04 for Coupe and wert_05 for Roadster.
I would like to understand these entries, mentioned by Beedub. In brackets is the setting for the standard M3, not in brackets is CSL/CS
UEBERSTEUERN_MUE_1_2 = wert_11 (wert_09)
UNTERSTEUERSCHWELLE_2 = wert_04 (wert_05)
UNTERSTEUERN_MUE_1_2 = wert_03 (wert_02)
Whilst researching, also seen mention of these settings
DTC_LAMPE = aktiv (nicht_aktiv) as we dont have the M Track symbol on the dash, I belive we need this set to nicht aktiv, which it may be by default anyway
PRE_MSR = aktiv (nicht_aktiv) - unsure what this is
BAUART_MK60 = csl (coupe_m or cabrio_m) - ?
DRUCKMODELL_HINTERACHSE = typ_3 (typ_2) - typ 3 is for ZCP brakes - I know we have CSL discs, but does a Z4M have ZCP calipers? (I am thinking yes, as the rear caliper on the Z4M is the same part number as the CSL, and has a larger piston than a standard M3)
Beedub wrote: FWIW just noted the m3 guys are able to get the actually M-TRAK light , some are getting the DTC light, but it seems this light can be activated too, anyone tried this one the z4m platform ??? guessing our cluster may not have that bulb.
http://forums.m3cutters.co.uk/showthrea ... 098&page=3
also to get the DTC set so its actually cutting in and out at he CSL spec M track we need to change these settings.. to these but they appear different in our data, so I'm not totally sure what we are activating in our instance but its definitely not the higher thresholds that the CSL have without changing the below... we seem to just be adding in the function from the 3.0Si which id guess isn't optimised for the M-diff...
UEBERSTEUERN_MUE_1_2 - wert_11
UNTERSTEUERSCHWELLE_2 - wert_04
UNTERSTEUERN_MUE_1_2 - wert_03
all info in the above thread.
turning on TDR isn't changing any values of the understeer oversteer cut in and outs i don't think, but not sure how to check???
is this a way to check the valves for the DTC mode?? and where do i change them, i can see the above germans sentences in the mk 60 module but how do we know if thats for the traction fully on, DTC , or the OFF mode settings?
Edit... after reading up on DTC we are definitely at a high wheel slip allowance.. so will try some different settings and report back,.
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
2003 Clio 172 Cup
I recently came across a place that do the recoding remotely called http://www.codemycar.com/
They can also do a whole heap of other things.
They are based in the USA.
I've got the software/cable to do this, but want to make sure I am changing the correct settings.
2003 Clio 172 Cup
2003 Clio 172 Cup
Sounds like a great upgrade, I will check if B & M in Glasgow can do this.
Previous
Volvo 360 GLS
BMW 318iS
Mercedes 230C
BMW 328 Cabrio
Audi S4 Avant
TVR Tuscan Red Rose
Lotus Elise 111S
Lotus Exige Cup 240
Porsche Boxster Spyder
Audi A3 eTron
Current
BMW Z4M roadster
BMW i3s
Volvo 360 GLS
BMW 318iS
Mercedes 230C
BMW 328 Cabrio
Audi S4 Avant
TVR Tuscan Red Rose
Lotus Elise 111S
Lotus Exige Cup 240
Audi A3 eTron
Current
BMW Z4M roadster
BMW i3s
