M Track Mode enabled on Z4MR
"M" Specific discussion
Beedub
Re: M Track Mode enabled on Z4MR
Post by Beedub » Fri Feb 12, 2016 5:48 pm
Herminator wrote:What cable did you go for? I think I'll have to give it a try too.
the one TomK linked in the first few pages.
cost me 35 quid delivered :-) installed parallels on my mac so i can run the software from my MBP.
Yorkie Z
Post by Yorkie Z » Fri Feb 12, 2016 6:06 pm
So what actually is M track mode.?
A Dirty M///
Scooba_Steve
Post by Scooba_Steve » Fri Feb 12, 2016 6:23 pm
Basically DTC right?
Beedub
Post by Beedub » Fri Feb 12, 2016 7:00 pm
well if everyones right its a specific mode a lower threshold on slip angle, As per CSL, CS.
pHilli0
Post by pHilli0 » Fri Feb 12, 2016 8:28 pm
My thought on this would be perfect for the road where you want some more fun but not dsc off in case you have a big costly mistake. On the track I just turn dsc off in all conditions to enjoy the car. Why would this M mode be better on the track ?
2006 Z4 ///M Coupe || Schrick CSL Cams | Eventuri | Brembo 6/4 & Pagid RS-29s | KW V3s | H&R ABRs | Stromung | ARC-8s | Corbeau Revolution | OEM Strut | ZHP | Stubby | CDV | RTAB | Evolve Map ||
http://www.phillynchracing.com/index.php/blog/
Online
AndyBeech
Post by AndyBeech » Fri Feb 12, 2016 8:39 pm
pHilli0 wrote:My thought on this would be perfect for the road where you want some more fun but not dsc off in case you have a big costly mistake. On the track I just turn dsc off in all conditions to enjoy the car. Why would this M mode be better on the track ?
Because you could have a big costly mistake as much on a track as you could on the road presumably....
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
pHilli0
Post by pHilli0 » Fri Feb 12, 2016 8:59 pm
Yea true. For me I am slowly becoming a better driver on track driving without any aids. I do fall off now and then of course, but I get a big sense of achievement catching a slide myself, rather than the lighting quick computer taking over. I guess it depends on how much room you have to play. If it only kicks in when you about to do a 360 then it might be just the thing.
mmm-five
Post by mmm-five » Fri Feb 12, 2016 10:11 pm
pHilli0 wrote:If it only kicks in when you about to do a 360 then it might be just the thing.
In my experience the DSC will not save you from a spin when you have to do an emergency manoeuvre in the wet :|
I tend to leave it on in the wet, and turn it off in the dry - and those slightly wider 265 PSS on the rear help.
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
Beedub
Post by Beedub » Sat Feb 13, 2016 3:14 pm
going to need to get a windows laptop, not happy with how the program runs on parallels , glad i only tried the trial before i went for the hole hog, parallels is slow and clunky.
Scooba_Steve
Post by Scooba_Steve » Sat Feb 13, 2016 3:19 pm
An old XP machine should do the trick. Virtualisation doesn't play ball on Win10 for me but was fine on Win7.
jpeeters
Post by jpeeters » Sat Feb 13, 2016 4:00 pm
VMware fusion 7 with Windows XP works flawlessly on my Macbook 12". I've used this setup to do my M-track coding.
Herminator
Post by Herminator » Sat Feb 13, 2016 4:02 pm
I have windows 8.1 here, is it going to be able to run the software?
BMW M4CS, San Marino Blue, CCBs
Gone but not forgotten- Z4M Roadster, E31 840 Ci Sport, E85 Z4 3.0 Sport.
Beedub
Post by Beedub » Sat Feb 13, 2016 5:02 pm
got hold of an old one from work, about to start again.... this one has vista.
just booting it up and giving it a good clean, it hasn't been used for years, lol, so many updates to instal but its running fast, so this one should do the trick.
ill keep it for coding only from now on.
Beedub
Post by Beedub » Sat Feb 13, 2016 8:30 pm
one last thing guys, is the e85/86 Kcan or Dcan ... both seem to cover the 2007 model year.... ones for Upto 2007 then Dcan is 2007+
Beedub
Post by Beedub » Sat Feb 13, 2016 8:33 pm
well software is all loaded up... after about 3 hours ;-P
so I'm about to go outside to the garage and have a go..... this to me is complicated s**t. lol!!
Edit; too cold in the garage, other things on my mind, tomorrow is proposal day for wifey :driving: :driving: taking her to the cotswolds so ill have to come back to this next week i think, everything is successfully loaded to the laptop so its a case of trying to understand the coding process itself, so it will give me a few days to swot up on the process.
