Z4M Engine Mounts / Bolts - **ALERT ALL Z4M DRIVERS**
- hopz121
Does anyone know if the E46 M3 suffers from this issue?
Was there a knock or a sign of something being wrong Bing?
Ash
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- Bing
Symptoms on page 3 Ash. I'm afraid I have no idea if the M3 suffers the same problem.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- hopz121
Thanks Bing ill have a look at mine on the M3 and see if they are similar (i'm guessing they will be)
- MrPT
I was checking my suspension today and thought I'd have another go at inspecting the driver's side engine mounts. All the visible bolts have looked ok in the past; it's just the couple behind the vanos pressure accumulator which have been tricky to inspect properly.
It was a proper sh!t to get sight of, but very glad I did now!
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Smartbear
That rear bolt looks like it’s backed out by a couple of threads
e85 3.0si sold
And then some...good job you looked Mr PT.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- MrPT
Feeling relieved to have caught it but also a bit silly. The bolt that I was lazy to check might be the one that's the most likely to back out or break, going by the stories in some of these threads.
What's the latest verdict re. replacements? Uprated OEM (10.9) bolts plus Nordlocks?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
No reason to change bolts MrPT, nordlocks and thread lock should suffice I would think.MrPT wrote: ↑Sun Jan 06, 2019 9:42 pm Feeling relieved to have caught it but also a bit silly. The bolt that I was lazy to check might be the one that's the most likely to back out or break, going by the stories in some of these threads.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- MrPT
They are stretch bolts so I’d like to bin them. Nordlocks feel like a good idea though.john-e89 wrote: ↑Sun Jan 06, 2019 11:00 pmNo reason to change bolts MrPT, nordlocks and thread lock should suffice I would think.MrPT wrote: ↑Sun Jan 06, 2019 9:42 pm Feeling relieved to have caught it but also a bit silly. The bolt that I was lazy to check might be the one that's the most likely to back out or break, going by the stories in some of these threads.
Might just remove the pressure accumulator and see how mobile that bolt is before speaking to my indie.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Smartbear
We used nordlock washers on trackside connections on London Underground, they seem to do the job.MrPT wrote: ↑Sun Jan 06, 2019 11:27 pmThey are stretch bolts so I’d like to bin them. Nordlocks feel like a good idea though.john-e89 wrote: ↑Sun Jan 06, 2019 11:00 pmNo reason to change bolts MrPT, nordlocks and thread lock should suffice I would think.MrPT wrote: ↑Sun Jan 06, 2019 9:42 pm Feeling relieved to have caught it but also a bit silly. The bolt that I was lazy to check might be the one that's the most likely to back out or break, going by the stories in some of these threads.
If over-torqued though, they can cause issues with the bonding of the two washer halves becoming unstable/failing.
e85 3.0si sold
Ah ok, stretch bolts, every days a school day...MrPT wrote: ↑Sun Jan 06, 2019 11:27 pmThey are stretch bolts so I’d like to bin them. Nordlocks feel like a good idea though.john-e89 wrote: ↑Sun Jan 06, 2019 11:00 pmNo reason to change bolts MrPT, nordlocks and thread lock should suffice I would think.MrPT wrote: ↑Sun Jan 06, 2019 9:42 pm Feeling relieved to have caught it but also a bit silly. The bolt that I was lazy to check might be the one that's the most likely to back out or break, going by the stories in some of these threads.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- flimper
My bolt from a few years ago
- image1.jpeg (89.02 KiB) Viewed 1344 times
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- MrPT
Ok, you win! Did you replace all the bolts or just the one that backed out?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- BMWZ4MC
I remember someone on here had the bolts back out completely leaving the engine resting on the ARB Does anyone know if these would have been replaced when my indie changed my engine mounts to VT mounts?
S2000 GT - gone
Ok, so guessing most folk will now look to check their car for this. Can you highlight exactly where to look in the engine bay for this?
