Just the problem bolt from memory
Z4M Engine Mounts / Bolts - **ALERT ALL Z4M DRIVERS**
- flimper
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
OnlineMrPT
Take the black plastic undertray off and the area in flimper's pic is the one highlighted below by the red arrow. If everything looks like a mess of similar colours, find the thick brown grounding cable to orient yourself.Angelus666 wrote: ↑Mon Jan 07, 2019 9:21 am Ok, so guessing most folk will now look to check their car for this. Can you highlight exactly where to look in the engine bay for this?
It's worth checking all the bolts, but the other six (four per side) are easy to see in comparison.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Bing
Probably me, in this thread Rich - mine was back in 2016, the pics are the page before this I think. I still have one of the sheared bolt heads on my desk as a souvenir
Unless they checked specifically I don't think they'd have replaced them - you'd know about it, IIRC the bolts are not cheap.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
That’s a great pic, thanks for posting MrPT....very helpful.MrPT wrote: ↑Mon Jan 07, 2019 12:17 pmTake the black plastic undertray off and the area in flimper's pic is the one highlighted below by the red arrow. If everything looks like a mess of similar colours, find the thick brown grounding cable to orient yourself.Angelus666 wrote: ↑Mon Jan 07, 2019 9:21 am Ok, so guessing most folk will now look to check their car for this. Can you highlight exactly where to look in the engine bay for this?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Also, can we presume that no garage would look to assess these as part of an Inspection II service...?
OnlineMrPT
You are welcome. I should reference the site I pinched it from, which has loads of high res pics of a factory condition Z4MC.
It's not on the Insp II checklist, but they might spot a problem with the driver's side mount when they are looking at the condition of the steering UJ (which is part of the list). I wouldn't assume anything though.Angelus666 wrote: ↑Mon Jan 07, 2019 4:40 pm Also, can we presume that no garage would look to assess these as part of an Inspection II service...?
A decent indie that knows the Z4M may well look at the mounts (and all other known issues) at every opportunity.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- BMWZ4MC
I thought it might have been yours but I wasn’t sure enough to say soBing wrote: ↑Mon Jan 07, 2019 3:43 pmProbably me, in this thread Rich - mine was back in 2016, the pics are the page before this I think. I still have one of the sheared bolt heads on my desk as a souvenir
In that case I’ll have to have a careful look at mine when I’m back in Aus.
S2000 GT - gone
- Bing
Yeah, not standard, but following the experience on my car my guys check all Z4Ms they get in for a service now, apparently. Including mine of course. Just have to be really precise when asking because first time round I was not and it turns out they had only checked the mounts themselves as I’d not explained properly.Angelus666 wrote: ↑Mon Jan 07, 2019 4:40 pm Also, can we presume that no garage would look to assess these as part of an Inspection II service...?
- Bing
Reading the original post back it looks like Jamie had the same issue of the engine resting on the ARB.BMWZ4MC wrote: ↑Mon Jan 07, 2019 5:48 pmI thought it might have been yours but I wasn’t sure enough to say soBing wrote: ↑Mon Jan 07, 2019 3:43 pmProbably me, in this thread Rich - mine was back in 2016, the pics are the page before this I think. I still have one of the sheared bolt heads on my desk as a souvenir
OnlineMrPT
Bought a couple of packs of M8 10.9 bolts (25mm and 35mm) plus Nord-locks for not very much money...
...and Vibra-Technics engine mounts. FFS.
- Smartbear
It’s only money, it’s better than wasting it on mortgage payments and gas bills
e85 3.0si sold
What’s the normal labour time to fit the Vibra engine mounts..? Think I might get these done during the next oil service.
OnlineMrPT
Quick question for anybody that knows their nuts and bolts -
The block is iron. I've bought generic, medium carbon steel bolts (10.9) because the equivalent spec ("motorsports") bolts are no longer available from BMW. I also bought some Nord-Locks, but have realised that they are stainless and that this might not be the best choice, given the load and the need to get the torque right (which, as I understand it, might be affected by galling). I think it will be fine, otherwise there would be a warning against using them in high torque scenarios, but can anybody confirm?
Not too worried about mild galvanic corrosion. I don't imagine the exposed parts will stay wet for very long.
It shouldn't take more than a couple of hours. From reading what others have done, the engine can be cleanly jacked up from below enough to change the mounts with no need for disassembly of the exhaust, transmission mounts etc.Angelus666 wrote: ↑Tue Jan 08, 2019 9:42 am What’s the normal labour time to fit the Vibra engine mounts..? Think I might get these done during the next oil service.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Form memory I think Beedub changed his on an axle stand and had a mare, then did the other side fully in the air, or at least twigged that would be so much easier so might be worth giving him a notification.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Argenta
Well soon 6 years into my ownership I accidently saw this today..
Needless to say I put a new bolt & springwasher in!
After reading a bit here, I prob should check out that 2nd bolt too...
- 082BD6BB-3945-42E3-8D6F-125D3C533CF6.jpeg (49.76 KiB) Viewed 965 times
