New Z4MR owner with a few queries
"M" Specific discussion
TomK
Post by TomK » Fri Aug 06, 2021 12:03 pm
AndyBeech wrote: Fri Aug 06, 2021 9:11 am Personal question but out of interest does anyone know why caster seems to vary a lot between Z4M's seeing as it's not adjustable? I've seen some with over 7 degrees and some as low as 5 degrees?
I'd imagine that's people fitting the non eccentric e46m3 lollipop bushes (which will give~ 5°) instead of the correct z4m ones to give the spec 7° :?
AndyBeech
Post by AndyBeech » Fri Aug 06, 2021 12:14 pm
TomK wrote: Fri Aug 06, 2021 12:03 pm
Yeah guess it must be. Wondered why I was sat in the middle at 6 degrees but maybe the Powerflex I've got fitted aren't quite the same spec as standard BMW bushes though are the correct Z4M offset ones.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
