Genuine CSL v CS Wheels
"M" Specific discussion
MKZ4000
Post by MKZ4000 » Tue May 25, 2021 9:32 am
I'm tempted to get some CS wheels for my Z4M
I've noticed the CS Wheels have different offsets on the front than CSL wheels.
Is that the only difference or are CSL wheels lighter?
Will CS work on the Z4M or are CSL's the one to get?
These are a link to the CS.
https://www.ebay.co.uk/itm/293131532197 ... 1438.l2649
Do you think that's a fair price?
BMW E85 Z4M
BMW E85 Z4 2.5
Gone Z4 E85 3.0
RedUn
Post by RedUn » Tue May 25, 2021 9:34 am
Rears are the same, front CSL wheels are 0.5 inch wider :thumbsup:
IMOLA Z4///MR
Probocop
Post by Probocop » Tue May 25, 2021 9:58 am
Yep the only difference is the CSL fronts are indeed a little wider, and subsequently very slightly heavier because of it.
Otherwise I believe they are identical, made of the same materials etc.
2007 Z4M Coupé - Midnight Blue
1988 VW Transporter - Slate Blue
2008 E82 123d - Space Grey
2009 Abarth 500 Esseesse - Campovolo Grey
MKZ4000
Post by MKZ4000 » Tue May 25, 2021 10:06 am
Will the fronts look ok being 0.5 inch less?
Logic says it would be barely noticeable
BMW E85 Z4M
BMW E85 Z4 2.5
Gone Z4 E85 3.0
bakes100
Post by bakes100 » Tue May 25, 2021 10:45 am
The CS wheels are 0.5 inch narrower (8") but also have 3mm more offset (+47 CS compared to +44 CSL), therefore they are sunken into the arch quite a way on a Z4m so would probably look strange without spacers.
Bear in mind the standard Z4M wheels are also 8" wide but have a +42 offset and they are already reasonably sunken into the arch as standard.
If it was me I would probably run the CS front wheels with a 12mm spacer to make them look 'right'.
2006 BMW Z4M Coupe - Sapphire Black
2007 BMW Z4M Coupe - Silver Grey - GONE
Probocop
Post by Probocop » Tue May 25, 2021 11:32 am
Also, worth factoring in CSL front wheels are NLA 😐
Probocop
Post by Probocop » Thu May 27, 2021 12:22 pm
Has anybody actually fitted the CS fronts to an M? It's an option I'm also exploring.
bakes100
Post by bakes100 » Thu May 27, 2021 12:26 pm
https://collectingcars.com/for-sale/200 ... 4m-coupe-2
This car is running CS front wheels, however I'm not sure whether it is running spacers on the front or not.
TomK
Post by TomK » Thu May 27, 2021 12:53 pm
bakes100 wrote: Tue May 25, 2021 10:45 am The CS wheels are 0.5 inch narrower (8") but also have 3mm more offset (+47 CS compared to +44 CSL), therefore they are sunken into the arch quite a way on a Z4m so would probably look strange without spacers.
Spot on. I had a set on the car a long time ago, pretty sure I ran a 12mm at the front. Tyres would have been 255/35 r 225/40 f, correct size for the CS.
Probocop
Post by Probocop » Thu May 27, 2021 1:00 pm
TomK wrote: Thu May 27, 2021 12:53 pm Spot on. I had a set on the car a long time ago, pretty sure I ran a 12mm at the front. Tyres would have been 255/35 r 225/40 f, correct size for the CS.
Thanks, the fitment looks nice. Are you running spacers on the rears?
TomK
Post by TomK » Thu May 27, 2021 1:32 pm
Probocop wrote: Thu May 27, 2021 1:00 pm Thanks, the fitment looks nice. Are you running spacers on the rears?
No I'm fairly certain it wasn't, but it was a long time ago.
Pretty sure this photo shows what they are like with no spacers, (none on the front so definitely not on the rear)
Probocop
Post by Probocop » Thu May 27, 2021 2:41 pm
Great, thanks. The spacers do make a good difference to the front :thumbsup:
Raj_UK
Post by Raj_UK » Thu May 27, 2021 3:12 pm
How come they worked on an M3 CS? Was the front track wider than a CSL or perhaps the wings narrower? Or did they just sit further in?
Z4less :?
TomK
Post by TomK » Thu May 27, 2021 4:00 pm
Raj_UK wrote: Thu May 27, 2021 3:12 pm Or did they just sit further in?
This. They're identical in size to the normal 19" diamond cut M3 wheel... and same tyre sizes 225/40, 255/35.
There's no difference other than small details (arb, dampers) of the front axles between CS and CSL, nor the wings.
M3 Front Rim : 8J et47
M3 Rear Rim : 9.5J et27
Raj_UK
Post by Raj_UK » Thu May 27, 2021 9:42 pm
TomK wrote: Thu May 27, 2021 4:00 pm
Cheers. Every day’s a learning day.
Z4less :?
