What is normal oil temperature?
OnlineMr Tidy
Inspired by "tiglon's" post on the E89 section I thought I'd ask on here because I've been wondering ever since I got my car, and probably am even more paranoid about it since I had the shell bearings replaced last year.
I don't pay much attention to the amber lights because they are all off almost before the gauge has moved off the stop!
My car has only ever got above about 90 degrees a couple of times since I had it and that only happens on hot days or when I've been sitting in traffic.
So I work on 90 degrees being fully warmed up meaning I can then give it some revs as/when appropriate.
But I'd be interested to know what temperature others' Ms run at, and their threshold for some fun!
Thanks.
Thanks.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Ed Doe
90-100 for me, 110 if driving enthusiastically. 125 on track
Edit - same as you mine never gets more than light throttle and less than 3krpm until its at 90, just not interested in chewing my new rod bearings either!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- BMWZ4MC
More or less as above:
- normal running once up to temperature just below 100C,
- UK track days about 110C,
- Aus track day maximum 125C
S2000 GT - gone
- mr wilks
With those temps It can't be coincidence that tracked S54s suffer more than non tracked , would you say the numbers above are "normal" for most cars on track days ?
I was watching the oil temps quite closely on my TTRS this weekend , ts had 450 hard miles added the last 3 days with a few others in the Lakes & Dales , yesterday particular hard climbing the passes over Kirkstone , Hardknot & Wrynose done after a few hours of enthusiastic mileage & oil temp peaked at 94c it predominantly sits around 90c .
Perhaps Bmw should have worked harder at keeping the temps down with a better / bigger fan coming in sooner ?
Are there mods you can do to them to help with engine cooling ?
I guess it also emphasises the importance of good quality clean oil at the right levels along with the right coolant mix .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Chippie
Normally for me the oil temp sits around the 90, driving hard around 100, I’ve seen it up to about 110 but no higher, I don’t think I drive it particularly hard though and haven’t done any track days.
The 35is is fitted with an air cooled oil cooler from production and I think the later 35i is as well,
Edit
Not paying attention, didn’t notice it was M specific so my comment isn’t really relevant
Edit
- Ed Doe
Not really no. 10w60 is designed to offer stable viscosity at high ttemperatures such as track applications - a side effect is that it's hideously thick when cold, which in turn is anecdotally at least a significant factor in rod bearing wear as technically the oil is too thick to offer decent protection when cold.mr wilks wrote: ↑Sun May 23, 2021 1:25 pm With those temps It can't be coincidence that tracked S54s suffer more than non tracked , would you say the numbers above are "normal" for most cars on track days ?
125c isn't particularly hot for a 10w60 oil, 145c is where the viscosity starts to change due to thermal breakdown.
- TomK
Exactly, castrol 10w60 is practically chilling at 125c, its shear value is around 145 as you say. I usually see around 120 on uk tracks but have seen considerably higher at 'autobahn' speeds of 1 hour plus 120-170mph. BMW design their cars to be used in this respect and many are. Rod bearing wear is almost beyond doubt caused by high loads when the oil is cold (and too viscous) and almost certainly has nothing to do with oil being too hot.Ed Doe wrote: ↑Sun May 23, 2021 3:37 pmNot really no. 10w60 is designed to offer stable viscosity at high ttemperatures such as track applications - a side effect is that it's hideously thick when cold, which in turn is anecdotally at least a significant factor in rod bearing wear as technically the oil is too thick to offer decent protection when cold.mr wilks wrote: ↑Sun May 23, 2021 1:25 pm With those temps It can't be coincidence that tracked S54s suffer more than non tracked , would you say the numbers above are "normal" for most cars on track days ?
Is that just your opinion with some random anecdotal support or are there some actual facts to back up this statement?
Yes
Even at 130c you're still far off the heat level that BMW constitute as too high according to their in car gauge, I'm not sure why anyone has a problem with that? It's not like we don't believe the petrol gauge
- mr wilks
I wasn't attempting to antagonize the track warriors, I was genuinely posting thoughts & reasoning.
As you were chaps, , once again il leave you with your high horses & pompous attitude yo anyone who doesn't own a sparco jumpsuit .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
My second S54 engine lasted 140,000 miles of road & track use before the rod bearings gave up.
I don’t know how many owners who say they “always warm up the car before thrashing it” actually do what they preach, but I purposely book a hotel further away from the track so that the car has a good 20 minute warm up driving period before getting ‘thrashed’.
I’ve read enough threads claiming one thing or the other kills engines. So mny anecdotal contradictions in fact that I’m totally confused, and will just continue to follow my own ‘scheduled+’ frequency of maintenance…and hope I get similar mileage out of my 3rd engine.
My previous 3 cars got to over 160,000 miles - a modified Corrado VR6 and 2 x e34 M5s - despite regularly (and more frequently than the Z4) thrashing them. But none of my cars have ever been a weekend/track only vehicle, so I’ll assume lots of regular/easy mileage with some thrashing thrown in doesn’t do the engine any harm.
Please take what you want from the above…I’m not here to proselytise
- TomK
You say that but it's not the first time of you insinuating that anyone who tracks their car is some kind of mad man who is inevitably going to blow up his engine. Firstly it really has nothing to do with the op's question so why bring it up and secondly I'm a bit surprised that you clearly feel aggrieved about someone questioning your "thoughts and reasoning" with some other reasoning and also some actual facts about the oil properties and what is normal. If that offends you and you think that's pompous then maybe best to keep those thoughts to yourself?
I'll leave you with your stereotypical views firmly intact no doubt, I have a feeling it's beyond any of us to change them
- Vanne
limp mode kicks in at 136 degrees. (not sure if thats intended or not, but thats when mine starts cutting fuel). i run mine anywhere from 120-135 on a really hot day. I hope to drop that by 5-8 degrees with the new oil cooler/meth setup.
I have to add, just talking about oil temp wont give you much of an idea about whats going on, you need to add oil PX and water temp to that picture. not too worried about oil temp really, its the PX thats important. esp on initial start and when warmed up.
Powered by Severn Tuning
OnlineMr Tidy
Thanks everyone.
I was just a bit concerned mine was hardly getting hot enough at 90 degrees but in road use that seems to be the "norm", with a slight increase when you get enough clear road to up the tempo a bit!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Ed Doe
Well no, it's more just rather irritating that you consistently offer commentary and conjecture on topics of which you know very little about. Some would call it scaremongering
Just count yourself lucky there are some at least who speak from research and experience rather than assumption and guesswork!
- mr wilks
The EdDoe TomK tag team strike again i wasn't even talkng to either of you so trot off & wash the sand out of your fanny .Ed Doe wrote: ↑Sun May 23, 2021 6:55 pmWell no, it's more just rather irritating that you consistently offer commentary and conjecture on topics of which you know very little about. Some would call it scaremongering
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Ed Doe
No doubt - I'm sure you were taking to people less well informed and less likely to challenge your drivel xxx
I thought you were leaving us to our respective high horses?
