Depressing...but onwards and upwards..!
That's not too bad, says a former MX5 owner
I’ll be doing vapour and soda blasting Steve. Vapour is wet blasting using glass beads and water at very high pressure, the beauty of this is its very gentle and won’t pit soft aluminium, you can clean cylinder heads and crank journals with it, it brings them up like new. The soda blasting cabinet is dry, the soda is so much softer than sand and again won’t pit soft metals, it’s just like icing sugar, so you can blast carburettors, ally parts, brass, copper, pretty much anything for the classic car, bike , boat, plane, agriculture market etc, etc. Lastly I have a mobile twin tank system, you can blast whole chassis with it, say a TVR Griff chassis, the beauty is you can blend in a harder blasting medium in the other tank if soda is not quite harsh enough. The soda is perfect for stripping paint from panels as well because traditionally sand blasting created heat that warped the panels but soda is so gentle it blasts cold, no distortion at all. It’s perfect for walnut blasting as well so I can blast a cylinder head ports then put it in the vapour cabinet and get it back to as new. It’s a leap into the unknown really but I think there’s a pretty big market as basically I can do anything from a rusty gate up to crank journals on an engine.mr.tourette wrote: ↑Sat Jan 30, 2021 3:10 pm not sure if ive missed a post somewhere but what is this new business venture John? heard you mention it many times now but not entirely sure what it exactly is
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
It’s a northern car but not Scottish Gaz, just two owners, the first an RAF rescue pilot so maybe it spent some time near the coast.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- mr.tourette
Sounds like quite the venture.. good luck with it all matejohn-e89 wrote: ↑Sat Jan 30, 2021 6:40 pmI’ll be doing vapour and soda blasting Steve. Vapour is wet blasting using glass beads and water at very high pressure, the beauty of this is its very gentle and won’t pit soft aluminium, you can clean cylinder heads and crank journals with it, it brings them up like new. The soda blasting cabinet is dry, the soda is so much softer than sand and again won’t pit soft metals, it’s just like icing sugar, so you can blast carburettors, ally parts, brass, copper, pretty much anything for the classic car, bike , boat, plane, agriculture market etc, etc. Lastly I have a mobile twin tank system, you can blast whole chassis with it, say a TVR Griff chassis, the beauty is you can blend in a harder blasting medium in the other tank if soda is not quite harsh enough. The soda is perfect for stripping paint from panels as well because traditionally sand blasting created heat that warped the panels but soda is so gentle it blasts cold, no distortion at all. It’s perfect for walnut blasting as well so I can blast a cylinder head ports then put it in the vapour cabinet and get it back to as new. It’s a leap into the unknown really but I think there’s a pretty big market as basically I can do anything from a rusty gate up to crank journals on an engine.mr.tourette wrote: ↑Sat Jan 30, 2021 3:10 pm not sure if ive missed a post somewhere but what is this new business venture John? heard you mention it many times now but not entirely sure what it exactly is
When the mobile car lift arrives I’m £40k in this venture Steve so......mr.tourette wrote: ↑Sat Jan 30, 2021 6:52 pmSounds like quite the venture.. good luck with it all matejohn-e89 wrote: ↑Sat Jan 30, 2021 6:40 pmI’ll be doing vapour and soda blasting Steve. Vapour is wet blasting using glass beads and water at very high pressure, the beauty of this is its very gentle and won’t pit soft aluminium, you can clean cylinder heads and crank journals with it, it brings them up like new. The soda blasting cabinet is dry, the soda is so much softer than sand and again won’t pit soft metals, it’s just like icing sugar, so you can blast carburettors, ally parts, brass, copper, pretty much anything for the classic car, bike , boat, plane, agriculture market etc, etc. Lastly I have a mobile twin tank system, you can blast whole chassis with it, say a TVR Griff chassis, the beauty is you can blend in a harder blasting medium in the other tank if soda is not quite harsh enough. The soda is perfect for stripping paint from panels as well because traditionally sand blasting created heat that warped the panels but soda is so gentle it blasts cold, no distortion at all. It’s perfect for walnut blasting as well so I can blast a cylinder head ports then put it in the vapour cabinet and get it back to as new. It’s a leap into the unknown really but I think there’s a pretty big market as basically I can do anything from a rusty gate up to crank journals on an engine.mr.tourette wrote: ↑Sat Jan 30, 2021 3:10 pm not sure if ive missed a post somewhere but what is this new business venture John? heard you mention it many times now but not entirely sure what it exactly is
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Those pesky SAR pilots!!!
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
No way...!!Simon 3.2M wrote: ↑Sun Jan 31, 2021 9:08 amThose pesky SAR pilots!!!
SERIOUS career envy....!!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Darren Slone
Best of luck John, if I know you it’ll be a proper top end job
Current Porsche Cayman S 987.1
Now sold - Imola Z4MC
Now sold - Silver Grey Z4MC
OEM CSL’s, Supersprint, Gruppe M, Eibachs, Carbon Roof, carbon rear spoiler,,
Now sold - My other Z
‘71 Datsun 240Z imported from West Coast USA
Are you just offering the various media blasting John or a finished coating too ?john-e89 wrote: ↑Sat Jan 30, 2021 6:56 pmWhen the mobile car lift arrives I’m £40k in this venture Steve so......mr.tourette wrote: ↑Sat Jan 30, 2021 6:52 pmSounds like quite the venture.. good luck with it all matejohn-e89 wrote: ↑Sat Jan 30, 2021 6:40 pm I’ll be doing vapour and soda blasting Steve. Vapour is wet blasting using glass beads and water at very high pressure, the beauty of this is its very gentle and won’t pit soft aluminium, you can clean cylinder heads and crank journals with it, it brings them up like new. The soda blasting cabinet is dry, the soda is so much softer than sand and again won’t pit soft metals, it’s just like icing sugar, so you can blast carburettors, ally parts, brass, copper, pretty much anything for the classic car, bike , boat, plane, agriculture market etc, etc. Lastly I have a mobile twin tank system, you can blast whole chassis with it, say a TVR Griff chassis, the beauty is you can blend in a harder blasting medium in the other tank if soda is not quite harsh enough. The soda is perfect for stripping paint from panels as well because traditionally sand blasting created heat that warped the panels but soda is so gentle it blasts cold, no distortion at all. It’s perfect for walnut blasting as well so I can blast a cylinder head ports then put it in the vapour cabinet and get it back to as new. It’s a leap into the unknown really but I think there’s a pretty big market as basically I can do anything from a rusty gate up to crank journals on an engine.
I’ll have to get into painting Gaz, enamel usually like you mentioned. For now if subframes etc, want powder coating I’ll farm that out, depends how much work I get for it will determine if I put a powder coating booth in, but I’ll be offering painting straight away, plus bush replacement so I send back a fully finished subframe.Z4M-2006 wrote: ↑Sun Jan 31, 2021 5:48 pmAre you just offering the various media blasting John or a finished coating too ?john-e89 wrote: ↑Sat Jan 30, 2021 6:56 pmWhen the mobile car lift arrives I’m £40k in this venture Steve so......mr.tourette wrote: ↑Sat Jan 30, 2021 6:52 pm Sounds like quite the venture.. good luck with it all mate
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Beedub
garage porn winner!!
cant wait to see where you take this john.. let me no when your up and running so i can support you like you have done me, ill send all my blasting work to you
- Vanne
Awesome, subbed for Resto goodness!!!
and good luck on your new business venture mate
Powered by Severn Tuning
Setting up shop at the next Zedfest John ??john-e89 wrote: ↑Sat Jan 30, 2021 6:40 pmI’ll be doing vapour and soda blasting Steve. Vapour is wet blasting using glass beads and water at very high pressure, the beauty of this is its very gentle and won’t pit soft aluminium, you can clean cylinder heads and crank journals with it, it brings them up like new. The soda blasting cabinet is dry, the soda is so much softer than sand and again won’t pit soft metals, it’s just like icing sugar, so you can blast carburettors, ally parts, brass, copper, pretty much anything for the classic car, bike , boat, plane, agriculture market etc, etc. Lastly I have a mobile twin tank system, you can blast whole chassis with it, say a TVR Griff chassis, the beauty is you can blend in a harder blasting medium in the other tank if soda is not quite harsh enough. The soda is perfect for stripping paint from panels as well because traditionally sand blasting created heat that warped the panels but soda is so gentle it blasts cold, no distortion at all. It’s perfect for walnut blasting as well so I can blast a cylinder head ports then put it in the vapour cabinet and get it back to as new. It’s a leap into the unknown really but I think there’s a pretty big market as basically I can do anything from a rusty gate up to crank journals on an engine.mr.tourette wrote: ↑Sat Jan 30, 2021 3:10 pm not sure if ive missed a post somewhere but what is this new business venture John? heard you mention it many times now but not entirely sure what it exactly is
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Bless you honey...Darren Slone wrote: ↑Sun Jan 31, 2021 4:31 pm Best of luck John, if I know you it’ll be a proper top end job
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
