Depressing...but onwards and upwards..!
- Jembo
The exhaust clamps have been known to be a weak point with corrosion ... cheaper to pay the £20 or so quid on fleabay for a stainless steel set rather than have them drop off on the road
- C0F7C07A-F4E8-42E5-AC92-5F53BB0F6D86.jpeg (125.83 KiB) Viewed 674 times
Lifer 54
Lifer 54
I honestly don’t know how it’s got so bad tbh M340, no idea if this is the norm and mostly hidden unless you get it on a ramp sire.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
It can’t stay like that can it Buzy....!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
It’s got to earn its living Mgarlane, rent isn’t free is it....!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- sars
That doesn’t look that bad underneath, nothing that can’t be made shiny again especially with what you’ve got tucked away in that man cave extraordinaire
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- pvr
The argument we always have on Porsche related discussions why some people like me won't drive their car over winter with salt. Road salt (or sea salt for that matter) will do something like that.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Looks pretty clean under yours Jembo...!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Yes we'll get it dealt with Sars, but it’s a pretty nasty sight when you’re a concours fan weirdo....!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- inkey$
What a project, This is going to be an interesting thread. Best of luck and I’m sure you’ll get her looking lovely
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
Thanks very much Inkey$...quite looking forward to it tbh.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Mr Tidy
That does look pretty scarey John!
But at least you've got the space and equipment to sort it out properly, so I hope you enjoy your project.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Crikey that's had to many days at the seaside in its life. But looking like it is all removable and replace/ treatable, especially with that awesome man cave you have. The floors look mint thought, which would be harder to repair than unboltable stuff.
Just going out in the garage to turn the humidifier up a bit more here
E86 In sapphire black
- mr.tourette
not sure if ive missed a post somewhere but what is this new business venture John? heard you mention it many times now but not entirely sure what it exactly is
That's just generally just surface corrosion, the only really nasty but are the track control arms.
I would say most of that is from driving on salted roads. Parked up if outside you will get condensation forming and corrosion, and also inside a garage if its not aired or heated, but not to that extent.
Most of this could be prevented by spraying the underside annually with ACF50. I have a bottle and an aerosol. It comes out slightly thick, so I am trying to work out the best way of applying a thin layer. I think a small air gun would work.
To remove light rust you can spray with an acid - the type used to remove salts from bricks, Phosphoric acid I think from memory, but its not that strong that when I used on bricks without gloves, it didn't sting, so fairly mild. I discovered this by accident as the overspray when applying to bricks removed the rust on some metal fixtures on the wall. I'm planning to spray the various bolts that hold the under shields with the HG stuff I have and then coat in ACF50. Its probably the same stuff you buy for rust removal, and I will buy some of the generic acid and dilute once I run out.
I'm now wondering if I have enough head height to get one of those scissor lifts!
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
2003 Clio 172 Cup
That an ex scottish car John?
We see a few like that..
All sortable though...... Get stuff enamelled,nicer than powder coat.
