It's an issue the same as the rod bearings / head gasket / VANOS are issues. Some people will experience them, some never will. Some will suffer these regardless of track work or not. It's just things to be aware of. Of course pushing the engine round a track is more likely to expose weak points already there, don't think that would be a surprise to anyone.mr wilks wrote: ↑Fri Oct 16, 2020 1:26 pmThe scaremongering being the caveats added at the end of post to remind all S54 owners that worn cams & followers is a very real issue but is it?? Or is it more prominent in cars pushed to the max of heat - cool - heat - cool in relative short bursts.AndyBeech wrote: ↑Fri Oct 16, 2020 1:02 pm Great post Ed, interesting read and good to see James is still doing excellent work down at Redish, hate to think what the final bill was for all that though Sounds like you've just been a bit unlucky to be honest as well as the previous rebuild not being up to standard going from what James said which no doubt was part of the problem. Least it's all sorted now though, take it they still didn't figure out why the noise went away for no particular reason at one point?
Plenty of people track standard S54 engine car's with no major issues apart from more regular maintenance and oil changes so not sure there's any scaremongering going on, just things to be aware of. From watching what James said it sounds a poor previous rebuild caused the issues here rather than excessive heat cycling etc. Sure Ed can shed more light on that though as he would have had more extensive conversations with James at the time no doubt. Not sure what the wheel caps melting has anything to do with the engine, AP brakes are going to produce a lot of heat on track but nothing out the ordinary (wonder if Tom has done the same at some point )
Pure opinion which I'm entitled to have & voice , you aren't of the opinion that engine went from good to bad at that moment between sessions purely by chance or bad luck are you? & suggesting the previous rebuild was iffy is also clutching at straws too , it's managed 10k with no issues
There is obviously a divided camp of owners Re tracking cars or not but fro. My own perspective I wouldn't knowingly touch any car that had track history with a barge pole let only a broom.
I don't think the engine went from good to bad by chance no, clearly there were issues already there that were exposed by being on track. I don't think you've read the thread properly as James says many times that he believes whoever did the previous rebuild has been heavy handed and maybe not done a great job as demonstrated by the damaged bolt threads so I don't see how that's 'clutching at straws'.
I don't think this thread is anything to do with whether tracking a car is bad or not, it's just Ed sharing his experience and pointing out again some already known potential weak points. The only thing obvious is that track work exposes weak points, doesn't mean it wouldn't have failed had it not been near a track at some point down the line with 'spirited driving'.
